Old 08-20-2013, 08:13 AM   #1
TV Reception
Anyone with a 8289WS having bad TV reception? I reset the channels every time we camp. Any tips that will help.
hammerhead is offline   Reply With Quote
Old 08-20-2013, 10:07 AM   #2
If you have LED lights that might be the problem. Learned that tip on this forum, and sure enough, a couple of our lights, when on, cause us to lose reception.
Hijinks is offline   Reply With Quote
Old 08-20-2013, 01:11 PM   #3
Paul & Sheri
pwb01's Avatar
I get excellent reception as long as there's a broadcast within maybe 30 miles or so. When your TV scans it will find different stations with the antenna pointed in different directions. Also, make sure your signal booster is on (light on). When it's off, you're in cable mode. My booster switch is located inside a cabinet under the TV and all three tv connections come from there.
2012 F150 F/X 4, 6cyl EcoBoost with Max tow pkg
2013 Rockwood 8280WS 5th wheel
2006 Sunline T1950
2004 T@B T-16
pwb01 is offline   Reply With Quote
reception, tv reception
