Old 07-26-2014, 10:40 PM   #11
harpman's Avatar
Originally Posted by mark0224 View Post
Another way to do the lone grey tank is hook up a garden hose with a valve at the open end to the cap on the tank . Run that hose over to the campground hook up. This way you don't have to crawl under a slide like on my trailer and you only need the one sewer hose plus the garden hose takes up less space. Leave the valve under the trailer open and when the tank needs draining open the valve at the end of the hose.
X2
Originally Posted by harpman View Post
X2
831RESS FLAGSTAFF
F150 FORD ECOBOOST
harpman is offline   Reply With Quote
Old 07-27-2014, 12:01 AM   #12
TxTravelingRN's Avatar
Two gray water tanks
Originally Posted by Helmsey View Post
This is what I use when I want both hooked up:
I generally only do that if we are going to be there for a week or longer. If just a long weekend I'll use a single hose and go to each drain when dumping.
I use this method as well. I also put valves at distal end of hoses prior to Y connection by CG drain to prevent back flow from 1 hose to the other when draining. 1 gray tank is under slide out and inaccessible so I leave that valve open and control with valve by CG drain .
2013 F350 Lariat 6.7 Diesel DRW
2013 Rockwood Ultralite 2608 WS
2013 Days Camping: 61
2014 Days Camping: 200+
TxTravelingRN is offline   Reply With Quote
Old 07-27-2014, 02:25 AM   #13
Owner/Operator
RodeoGeorge's Avatar
On my 8289WS I combined the two outlets. I procrastinated on doing this a long while, as I was apprehensive about possibly messing something up.
The way that I did it provides a method of disassembling the pipes should you need to replace the seals in the valves.
Combine Dump Outlets
RodeoGeorge
2013 Rockwood 8289WS
Mods: Central Vac, PI EMS-HW50C, 2025RV, (2) SCS225 Trojans, PD9260, Awning Remotes & LED Lights, Eliminators, External Water Filter,, Intellijacks
2008 RAM 3500 Cab&Chassis Hauler Bed, B&W Companion Hitch
All My Modifications are at this link:
http://www.forestriverforums.com/for...ons-36212.html
RodeoGeorge is offline   Reply With Quote
Old 07-27-2014, 06:26 PM   #14
B and B's Avatar
RodeoGeorge
George, I also have not done this either. I do like you idea using the flange like a union. That was part of my thoughts how do you take it apart if you have to.
Brian
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
Old 07-27-2014, 06:33 PM   #15
I hard plumbed the galley tank into the grey tank my 08 Flagstaff and our present 12 Flagstaff 8528RKWS. One outlet, one hose to dump all 3 tanks.
Connect Galley tank to Front grey water tank
Old 07-28-2014, 04:30 PM   #16
Owner/Operator
Brian
Just remove the four bolts that hold the two flanges together (with the seal between them) and then any part of the system can be removed/serviced.
RodeoGeorge
Old 07-28-2014, 05:09 PM   #17
I too have two grey tanks.The kitchen dump vale I installed the garden hose end cap and bought the sewer flange that has the garden hose inlet.Rigged up a swivel fitting and plug for it.I just hook up the hose and leave the valve open on the 5er.Easy peazy.Use the hose for the black tank flush when I'm ready to dump.
DaveandSue is online now   Reply With Quote
Old 07-28-2014, 06:50 PM   #18
harpman's Avatar
I also use this method..to me it's the most simplistic
831RESS FLAGSTAFF
F150 FORD ECOBOOST
Old 07-29-2014, 10:23 AM   #19
Helmsey's Avatar
I hadn't thought about adding valves but did want something to prevent back flow into the other hose. I guess I was over thinking it and trying to make it too hard. Thanks for the idea
2015 Chevy 3500HD
2013 Sandpiper 365SAQ
Helmsey is offline   Reply With Quote
Old 07-29-2014, 10:33 AM   #20
jevanb's Avatar
why in the world did they, FR, put 2 drain outlets under any coach.. Unless their is no room for the single to join.. I have 4 tanks, 2 in the back and 2 just in front of the wheels and all exit out of 1 outlet in front of the wheels
2012 Wildcat 344QB
06 LBZ ,CC 4x
lots of mods
Superglide
jevanb is offline   Reply With Quote
tank, water, water tank
