Old 10-17-2015, 10:35 PM   #11
dougk53's Avatar
Previous truck kept it in the rail mounted bed box on a shelf with easy access. Current truck has a floor mounted bed box so it goes in a storage well under the back seat which is always up anyway for the dogs. If you want to keep it in the storage compartment in the trailer wrap it with a couple pieces of Velcro and place corresponding pieces on the sidewall next to the door in a vertical position so it will be easy to find.
Doug
Doug, Virginia, Buster & Sam
2017 Ram Crewcab 2500 6.4 Hemi Delmonico Red Pearlcoat
2015 Flagstaff 27RLWS
2005 Road King
5 Grandkids
Brianna,Frankie,Tyler,Tori&Jocelyn
dougk53 is offline   Reply With Quote
Old 10-18-2015, 03:22 AM   #12
On all our previous travel trailers, I've installed a pc of 5/8" rebar or 1/2" emt to one of the bolts holding the tongue jack on and simply slide the break over bar on the rod or emt. Never lost one in over 30 yrs of using trailers with wdh.
They are always handy and right where you need them. I've seen some folks just mount a couple of broom holders to do the same thing.
Name:	Hitching mirror showing ball socket painted white.jpg
ID:	91993   Click image for larger version
Name:	Holder with open bottom for 7 pin connector.jpg
ID:	91994   Click image for larger version
Name:	Spring Bar Handle Holder.jpg
ID:	91995   Click image for larger version
Name:	Spring Bar Handle In Place.jpg
Old 10-18-2015, 05:07 AM   #13
Fred H.'s Avatar
A 3/4" black pipe or galvanized, 18" to 24" found at Lowes or Home Depot will work perfectly. Just make sure it's a piece of steel pipe not conduit for strength.
Fred n Wilma
2017 Ford F-150 EcoBoost
2015 Crusader 295RST
Fred H. is offline   Reply With Quote
Old 10-24-2015, 10:20 AM   #14
I found it!! I was in the compartment and rolled to the front under the door, I didnt see it. Thought I was going crazy as I remember putting it away.
Thanks for all the great ideas! Love this forum
2016 Rockwood Ultra Lite 2604WS
2004 Dodge Ram 2500 CTD 5 speed Manual 4x4 Laramie
2005 Ford Mustang Convertible
1993 Jeep Wrangler YJ IL6 4.0 lifted (love it)
Happy Trails All!!
roaddiva is offline   Reply With Quote
Old 10-27-2015, 09:30 AM   #15
Learning a lot as I go...
I have to point this out from my earlier posting:
Originally Posted by stevejahr View Post
That little sucker sure does hide well... mine loves to roll over against the side and disappear under the edge of the cargo access door. I swear I am going to put in some kind of bracket or holder for it on the front wall.
Glad you found it, sounds like right where I suggested
stevejahr is offline   Reply With Quote
Old 10-27-2015, 10:36 AM   #16
Yes it was and I think that will now be the storage spot for it!!! Hahaha!
Happy Trails All!!
