DE-WINTERIZATION / REMOVAL OF ANTI-FREEZE
If purchasing a coach that is winterized with RV anti-freeze or having had an existing unit winterized before winter storage, the plumbing system must be flushed and sanitized prior to use. Do not attempt to turn on water heater if system is winterized. Perform the following prior to attempting to operate the water heater or use the plumbing system.
1. Drain all tanks (fresh water and sewage)*
2. Attach garden hose to fresh water fill and fill tank.
3. Turn on pump switch and open cold water side of all faucet/ shower fixtures. Leave open until water runs clear. Repeat for hot water side. 4. Flush toilet until clear water runs into bowl.
5. Dump tanks again.
6. Sanitize water system.
7. If a water filter is installed, drain lines, remove filter assembly, clean and reinstall with new filter. 8. When ready to use the water heater, turn by-pass valve to open position to allow water to enter hot water heater tank and fill according to instructions.
* Waste water tanks must be dumped at state approved locations.
