Old 05-29-2015, 11:35 AM   #11
Originally Posted by BruceM View Post
Forest River needs to spec better bed support rods.
The ones I'm thinking of lock in place when you lift the bed up and then unlock when they are lifted slightly from the locked position.
They are mechanically actuated struts, not relying on gas under compression.
They've used gas struts on the tailgates for cars, minivans, SUVs, ect... for years with no problems.
Iwritecode is offline   Reply With Quote
Old 05-29-2015, 12:16 PM   #12
BruceM's Avatar
They do wear out. I replaced the rear window struts twice on an Astro Van I had.
And in this case, on the Rockwood trailers, they are not strong enough to hold the bed up.
If they work so well on mini vans why do they not work on the Rockwoods?
2015 Rockwood MiniLite 2109S
2018 Ford F150, 3.5L ecoboost
Blue Ox SwayPro hitch
BruceM is offline   Reply With Quote
Old 05-29-2015, 12:35 PM   #13
Traveling Two
jerryliving's Avatar
I made access to under the bed with two drawers on each side in lieu of fighting with opening of the bed.
jerryliving is offline   Reply With Quote
Old 05-29-2015, 12:47 PM   #14
Life Without Whine's Avatar
We just use that for more of the long term storage ...crock pot, extra paper goods, extra towels ....that way my back doesn't get worn out going in & out too often :-)
Terri & Joe, Roxie & BrewDog Boont
Camping on average a long weekend every month since starting in May of 2013 .... Florida is a great state to have this bad habit
Life Without Whine is offline   Reply With Quote
Old 06-01-2015, 12:09 PM   #15
Agreed that they do wear out. Although I've driven numerous vehicles with rear hatches for many years and have only had to replace one in my life.
My previous trailer was a Wildwood with struts under the bed. I almost had to put my entire weight on it to get it to close again after I opened it. So they worked extremely well.
As for the people having trouble, I can only assume their struts are either undersized or wearing out. I can't imagine the beds weigh any more than some of the tailgates the struts hold up.
Old 06-01-2015, 12:20 PM   #16
becca4vols's Avatar
Ours locked into place and wouldn't unlock (even when we lifted from the locked position) the first time we took our TT out. So my husband removed them. It would be nice to have something that would work because now it is a two person job to get into the under bed storage.
becca4vols is offline   Reply With Quote
Old 05-16-2016, 09:51 PM   #17
My bed is on a slide! Has anyone found a system that works with the slide?
Slinks is offline   Reply With Quote
Old 05-17-2016, 12:53 AM   #18
Blog: RVroadtripper.com
hbillsmith's Avatar
Mine came with 80# gas struts. The size is printed on the side. I believe all use 10mm ball mounts and are 20" length with 8" stroke. You can replace with 120#, 135# or 150#. Amazon cost is about $25. Thats what I did.
Maxxis 235/80/16E; AirBags w/AirLift 1 wireless compr; 4-Fold Tonneau; 6000# Dexters; mor/Ryde Rubber Pinbox & CRE3000 w/HD Wetbolts; Andersen UltimateII Aluminum 5erhitch on Reese Flipball w/Curt 4" offset ball; LCI Ground Control3 4pt+2pt Elec.Rear stabilizers; 3 Slidecovers; King Dishtailgater; 10ft. Portabote w/5hp Outboard; Dual A/C; Furrion48 Rearcam; Champion 3100 Inverter w/DIY Extended Run
hbillsmith is offline   Reply With Quote
Old 05-17-2016, 04:56 AM   #19
Members who put "Memory Foam Toppers" on top of their Factory Matt.add a LOT of weight! Most of the time "Strut and Geometry" change is required also! Youroo!!
Old 05-17-2016, 07:56 AM   #20
I think my issue is the slide! The wood platform slides in and out, while the box remains stationary. Don't think there's anything that can be "fixed" in this case
bed, storage
