Old 10-04-2013, 09:19 AM   #1
Unhappy Under bed storage panel pulled out on 2109S
This is on a 2012 Mini Lite 2109S and is the right side panel on the under bed storage compartment. It looks like the panel was pressed on to metal pins on the aluminum frame and some adhesive applied.
My intended repair is to re-align the panel, apply some adhesive, pull/push/hammer it back on to the pins and issue a stern warning to DW not to over pack the storage area under the bed.
Has anyone seen this happen before? Any comments on repair method?
Thank you
ID:	40635   Click image for larger version
2016 Chevy Silverado 2500HD Duramax LTZ Z71 Extended Cab, Long bed
2012 Dodge Ram 1500 5.7L Hemi
(with K&N Air Intake) (traded)
2012 Rockwood 2109S (Sold)
2014 Cougar X-Lite 21RBS
wbdvt is offline   Reply With Quote
Old 10-04-2013, 09:56 AM   #2
Thanks for the heads up. I haven't had that issue yet on my 2013 but we don't put too much in there really. I'll keep an eye on it.
2013 Rockwood 2109S
2010 Dodge Ram 1500 Crew Cab 4x4 Hemi
GearHd6 is offline   Reply With Quote
Old 10-04-2013, 10:07 AM   #3
Why not just remove all the pins/nails/staples and install a piano hinge?
Old 10-04-2013, 10:13 AM   #4
Well it doesn't need to be opened for anything. It would also need to latched then and it is a very thin piece of panel.
Old 10-04-2013, 10:18 AM   #5
Does the mattress not sit on it? Our 5er has the lift up without a latch. I know it is thicker, but with the mattress on top, don't see a need for a latch and access into the compartment would be a lot easier than using a door on your knees. Just saying.
Old 10-04-2013, 10:27 AM   #6
Looks like a saw cut on the left side? Also looks like (Pop Rivets)to me. Youroo!!
Old 10-04-2013, 10:29 AM   #7
It's the end panel to the compartment not the hinged lid. The picture is deceiving.
2013 Rockwood 2109S
Old 10-04-2013, 10:34 AM   #8
That makes more sense, the picture should have been rotated 90į clockwise.
Old 10-04-2013, 11:09 AM   #9
Same thing happened on our 21FB. Less than a year old. FR's funky pins are useless. I replaced them with some small metal screws. Due to the bed overhang the screws are not really noticeable. On something like an RV (vibration and movement) there is nothing better then a good old fashion screw.
Acsimon
2008 Jeep Grand Cherokee (5.8 Hemi)
2013 Flagstaff Micro Lite 21FB
acsimon is offline   Reply With Quote
210, 2109s, bed, led, storage
