Old 12-24-2015, 06:42 AM   #41
bareftn's Avatar
I don't understand why this question come up so many times? you don't unhitch when you stop for gas or eat so what's the problem when stopped overnight?
bareftn is offline   Reply With Quote
Old 12-24-2015, 06:45 AM   #42
I pull the plug from the TV because years ago my other truck's batteries were drained when I left it plugged in overnight. I have a newer one but same make now and I do it out of habit. Not fun getting up early, get in the truck and no go. Had to shut it off at the US border side and was keeping fingers crossed that it would start again...it did.
Pipeman is offline   Reply With Quote
Old 12-24-2015, 06:47 AM   #43
Left Coast
IT's the op's 4 post....explained in first post....
Old 12-24-2015, 07:01 AM   #44
Georgia Frog Rally 2018
aceinspp's Avatar
No problem leaving hitched . Just make sure to pull the trailer plug out from tv. I had blown fuse on truck by leaving it in and hooking up shore power cable. Later RJD
2018 Dodge Ram 2500 6.4 3:73 gearing.
Days camped in 2016 58
Days camped 2017 62
Days camped 2018 18
Old 12-24-2015, 07:15 AM   #45
We have left connected to the TV, unplugged the 7 pin and just put the stabilizers down to just touch the ground. We have had no problems!
CTGREG is offline   Reply With Quote
Old 12-24-2015, 07:30 AM   #46
Phat Phrog Stunt Crew
elind's Avatar
Originally Posted by Crusadernoob View Post
Overnighted in motels?????
You were pulling your bed??????
When your pulling a winterized 5er in February looking for warm weather, it's nice to have a hot shower and some comforts. It took us three nights before we found warm enough weather to un-winterize.
2014 Wildcat 327ck
elind is offline   Reply With Quote
Old 12-26-2015, 10:54 AM   #47
Please advise why to unplug from the TV.
DrippingDuo
Chappy and Liz
Dripping Springs, TX
DrippingDuo is offline   Reply With Quote
Old 12-26-2015, 11:04 AM   #48
Todouble's Avatar
Some vehicles don't have a relay to disconnect the vehicle power from the trailer power. If you stay in your rig overnight and run down the battery there's the risk of taking the vehicle battery with it. It would suck to wake up with dead batteries all around.
Todouble is offline   Reply With Quote
Old 12-26-2015, 12:38 PM   #49
Left Coast
Take a meter and check from trailer plug to battery for continuity.. in trailer
Old 12-26-2015, 01:16 PM   #50
See attached pic. The pic on the left is looking into your TV connection. Use your meter to read across the connection at the 1 o'clock position (+12VDC) to the 7 o'clock position (ground) with the TV off. If you have voltage, you're going to want to unplug the trailer from the TV.
Name:	Vehicle 7-pin connector.jpg
2011 Traverse LT, 3.6L, FWD
hitch
