Old 09-13-2014, 06:24 PM   #11
I have a Mini Lite 2503 and I pull it with a Nissan Frontier. Went to Park city Ut from Grand Jct Co over soldier summit and up Provo Canyon with no problem. Gross combined wt. is 9500 lb. The gross combined wt rating for the Frontier is 11250 lbs.
Sent from my iPad using Forest River ForumskR
weatherl is offline   Reply With Quote
Old 09-19-2014, 10:03 AM   #12
SkipBest's Avatar
We are looking at a new 2503, how do you like your trailer? I am worried about the clearance under the sewer pipes in the rear of the unit. To me they look like they are just waiting to be snagged on something. Have you had any issues with these pipes being exposed to damage? Have you been happy with the AC? It seeks fine to us but the larger unit is an interesting option. How does the. TV work while using the antenna?
SkipBest is offline   Reply With Quote
Old 09-19-2014, 06:14 PM   #13
We like our Minilite very much , it is a typical RV as I have had every thing from a 40 ft motor home to a tent trailer they all have small problems due to the poor quality control at the factory. I have not had any issue with sewer connections . The AC seams to work fine , I have only used it a couple of times. The tv works great , I installed a different TV that I had from another home. We also took the couch out and put 2 Lazyboy recliners in place.
Old 09-19-2014, 06:44 PM   #14
SkipBest's Avatar
Thanks! Any items to take a special look at during the PDInspection? We can't wait to have a "real" travel trailer after having a pop-up.
Old 09-19-2014, 06:59 PM   #15
Check all the cabinets and draws to make sure they work the way they should. The most problems I always found was the factory workmanship. Most of the appliances and things the factory doesn't build seam to be ok.
Old 09-19-2014, 07:01 PM   #16
SkipBest's Avatar
THANKS...we will give all of the doors, drawers, windows and plumbing a close examination. Thanks for your advice.
