Old 09-27-2015, 04:30 PM   #1
Used 2304KS
I am about to pull the trigger on a very lightly used 2304KS. This will be my first travel trailer purchase. Is there anything I should look for being that this is a used unit? I will be pulling it with a 2014 Ram with the V8 Hemi engine. The trailer dealer is going to set me up with a WDH, sway bar and brake controller. Any tips or thoughts on this set up would be appreciated.
Jimmyk is offline   Reply With Quote
Old 09-27-2015, 04:58 PM   #2
Should not be a problem at all as long as you get a anti sway WDH. I have a 2304KS and my TV is a Dodge Durango with the Hemi. I have the 4 point equalizer hitch and when on I-40 with semi's passing me almost no trailer wag or drag. Also the Hemi doesn't even go beyond 3500RMP going up hills. So far have enjoyed the trailer.
bailer6334 is offline   Reply With Quote
Old 09-28-2015, 06:42 PM   #3
Thanks for the reply. I closed the deal today. Glad to hear how good the Hemi performs.
Old 09-30-2015, 06:46 AM   #4
I added the factory brake controller to my 2010 Ram. It looks clean and shows up on the dash display if the dealer flashes it into the trucks computer.
2013 Rockwood 2109S
2010 Dodge Ram 1500 Crew Cab 4x4 Hemi
GearHd6 is offline   Reply With Quote
Old 09-30-2015, 06:04 PM   #5
I also should add I installed a Tekonsha P3 Brake Controller and purchased the plug & play wire connector assy (from vehicle to P3) specific to your vehicle. Amazon is the place to get both at a reasonable price. Make sure you get the correct wire assembly for your vehicle.
Old 09-30-2015, 07:37 PM   #6
I actually negotiated the break controller and weight distribution hitch into the deal. Thanks for your help and suggestions. I hope they put on decent components. He did mention Tekonsha.
