10-11-2016, 10:43 PM
V-Series 2715VS OR Ultra Lite 2604WS
My wife and I would like to upgrade from our 2015 Wildwood 241QBXL to the Rockwood V-Series 2715VS. That floor plan is exactly what we want. The problem is that I don't see a way to install my 2 Trojan 6v batteries. I can see that there are 2 storage areas on both sides of the front V. I assume one side has the propane tanks. Can I fit the 2 batteries in the other front compartment? If there is no possibility of using my Trojans we'll probably opt for the more conventional Ultra Lite 2604WS which has a similar floor plan but recliners don't seem to be an option on that one.
Thanks,
OldBob
I may be old but I'm trying, very trying.
2015 RAM 1500 - EcoDiesel
Rockwood Ultra V 2715VS
10-11-2016, 11:27 PM
Find a local dealer who has one and check it out.
10-11-2016, 11:58 PM
I'm not affiliated with the content provider in any way.
2011 Nissan Xterra V6
2016 Rockwood MiniLite 2306
Nights Camped 2016 [24]
Nights Camped 2017 [63]
Nights Camped 2018 [27]
10-12-2016, 12:42 AM
Compare the tongue weights (add 7 pounds per gallon for any water you will be carrying in front of the axle) Then add your weight, your passenger's weight and anything else you are going to carry on the bed or cab. The Ram 1500 EcoDiesel can carry about 1200lb. (Rough estimates)
Most of the storage on the 2604ws is in front of the axle. (More tongue weight)
I pull the 2604ws with mine. Although my truck pulls this trailer just fine, I would be reluctant to pull anything with a heavier tongue weight.
It's not the pulling capacity (9200lb with the 3.92 rear end) that is the limiting factor, it's the load carrying capacity (1200lb ?)
10-12-2016, 02:59 AM
Thanks all!! Great info as always on this forum. I appreciated the video links (thanks Nurek) and learned that there is no sealed bottom to the access areas in the front V so no worries about mounting batteries there. I also appreciated the advice from Croaker since we have the same tow vehicle.
Thanks again!
OldBob
10-12-2016, 06:04 AM
Both of those front cargo doors are for your propane tanks - one goes in from the left and one goes in from the right. I suppose you could eliminate one of the tanks.
Bruce
10-12-2016, 06:33 AM
There is nothing behind those doors to set a battery on. That's where the Lp tanks sit... and you will want the 2017 model for the beefier axles and bigger tires and rims. With the VRL you will get a full size queen instead of a short one
2016 Flagstaff 27VRL Emerald
14K Equalizer
2020 Silverado 2500HD CC 4X4 6.6L gas 3.73
10-12-2016, 12:51 PM
VaJim
battery
Remove your battery and have a plate welded on it an then reinstall batteries on it.
2010 Ram 1500 Quad 4X4 5.7L
2012 V-LITE 30WFKSS
10-12-2016, 07:24 PM
X2 what Croaker said - see my signature below
2015 Rockwood Ultra Lite 2604 WS. Rear LR, large street side slide with small wardrobe slide in BR.
2014 Ram 1500 Eco Diesel Laramie Quad Cab.
10-12-2016, 08:08 PM
We have a WJ but I would think it would be just about the same up front. Ours came with 2 batteries. There is a mounting plate bolted to the frame and 2 battery boxes.
2016 Windjammer 3006WK - Sold July 2018
2002 Lance Lite 835EC TC - Sold July 2015
2010 Dodge Ram 2500, 4x4, Diesel, Front Hitch, Air Lift 5000 Rear Air Bags, Sold Mar 2019.
MISSION COMPLETED!
10-12-2016, 08:28 PM
HI here is a century battery box that may work.
Century Plastics: White Heavy Duty Battery Box - (part#: GCE-G)
This is 6 volt battery box but they have battery boxes for 12 volt battery also. I have seen this battery box installed on an other v nose trailer. There was no problem with the propane compartment door operation and the battery box. The steal support may that holds the box may need to be modified to hold the larger battery box. I am going to make this mod before I go to Alaska in 18. I have the Flagstaff V-Lite version of the windjammer 3025w with the front bathroom. I was all so looking at putting 2 agm under the sinks along with a dc to ac pure sine wave inverter. I want the extra battery power so I can run the furnace at night and not drain more than 25% of the battery's over night with out running the generator.
Hope this helps Tim
10-12-2016, 11:49 PM
Bruce
Yes...I see that. I was actually thinking that I might switch those for the smaller 20lb tanks. It's so easy to swap them out for full ones just about anywhere.
OldBob
10-12-2016, 11:54 PM
Yeah...having a full sized queen bed sounds awfully good to me being 6'1''. Thanks for letting me know about the 2017 model. Our Wildwood came with undersized tires which I almost immediately replaced with proper ones.
OldBob
10-12-2016, 11:56 PM
That'll work for me. I do think the VL is they way I want to go. Love that mid bedroom floor plan!
OldBob
10-12-2016, 11:58 PM
Fabulous. That's an easy mod for me to make. I have no welding skills but I can drill and put nuts and bolts in all day long, even at my age.
OldBob
10-13-2016, 12:57 AM
Hope this helps Tim
Good find! Sounds like an ideal battery box. In my present Wildwood I use a 1000w inverter connected to the entire trailer. To do this you must make sure the converter is switched off when the inverter switches on or else you could have an electrical loop and damage the batteries or even start a fire. A double pole switch is a good way to go which switches off the converter while turning on the inverter. Having it connected this way we have 110v in all of our outlets while dry camping and the 1000w is enough to power the toaster, Keurig Coffee maker, vacuum cleaner, etc. I charge the Trojans daily using a generator and a stand alone high amperage charger. After using this setup for 2 years we've never had a problem and the batteries perform as new.
OldBob
10-13-2016, 06:11 AM
You'll also get the recliners with the V. I think the other TT has just the swivel rockers because there is less distance from the back wall to the cabinets in front of the chairs compared to the VRL and the recliners won't work there. The exit doors are different on the 2017 to 2016( no gas shock) , but there is a opening limiter built in. The switches on the WH are both inside on the panel..electric too! I've made tons of mods on mine, but we enjoy it
14K Equalizer
10-13-2016, 06:24 AM
Georgia Rally Coordinator
I made my own bracket to hold two batteries for my V-Lite. Later RJD
Traded 2015 30WRLIKS V-Lite
Days camped 2019 62
10-13-2016, 07:15 AM
I have same truck and trailer, except I have 3.55 gears. The truck pulls it fine, but like you said, the 2604 is a little tongue heavy. I'm a couple hundred over on payload, but do not exceed axles according to the scales.
Just want to add that my 2016 2604WS came with recliners. The VL was on my short list, and in fact, I preferred it on several levels.... the killer for me was the fact that you could not get to anything with the slides in. I tried, if i could have used it for quick overnights with the slides in, I would have likely gone that way.
Good luck with your decision!
John and Linda
2016 Rockwood 2604WS
2017 Ram 3500 CTD SRW
2016 - 47 nights
2017 - 47 nights
