Old 10-11-2016, 11:43 PM   #1
V-Series 2715VS OR Ultra Lite 2604WS
My wife and I would like to upgrade from our 2015 Wildwood 241QBXL to the Rockwood V-Series 2715VS. That floor plan is exactly what we want. The problem is that I don't see a way to install my 2 Trojan 6v batteries. I can see that there are 2 storage areas on both sides of the front V. I assume one side has the propane tanks. Can I fit the 2 batteries in the other front compartment? If there is no possibility of using my Trojans we'll probably opt for the more conventional Ultra Lite 2604WS which has a similar floor plan but recliners don't seem to be an option on that one.
Thanks,
OldBob
I may be old but I'm trying, very trying.
2015 RAM 1500 - EcoDiesel
Wildwood X-Lite 241QBXL
OldBob is offline   Reply With Quote
Old 10-12-2016, 12:27 AM   #2
Iggy's Avatar
Find a local dealer who has one and check it out.
2012 Georgetown XL - 378TS 49,900 miles
(2013 - 98 days) (2014 - 117 days) (2015 - 67 days) (2016 - 111 days) (2017 Est 115)
USAF Retired - MSgt
Old 10-12-2016, 01:42 AM   #4
Croaker's Avatar
Compare the tongue weights (add 7 pounds per gallon for any water you will be carrying in front of the axle) Then add your weight, your passenger's weight and anything else you are going to carry on the bed or cab. The Ram 1500 EcoDiesel can carry about 1200lb. (Rough estimates)
Most of the storage on the 2604ws is in front of the axle. (More tongue weight)
I pull the 2604ws with mine. Although my truck pulls this trailer just fine, I would be reluctant to pull anything with a heavier tongue weight.
It's not the pulling capacity (9200lb with the 3.92 rear end) that is the limiting factor, it's the load carrying capacity (1200lb ?)
Croaker is offline   Reply With Quote
Old 10-12-2016, 03:59 AM   #5
Thanks all!! Great info as always on this forum. I appreciated the video links (thanks Nurek) and learned that there is no sealed bottom to the access areas in the front V so no worries about mounting batteries there. I also appreciated the advice from Croaker since we have the same tow vehicle.
Thanks again!
OldBob
Old 10-12-2016, 07:04 AM   #6
nomad297's Avatar
Both of those front cargo doors are for your propane tanks - one goes in from the left and one goes in from the right. I suppose you could eliminate one of the tanks.
Bruce
Old 10-12-2016, 07:33 AM   #7
jeff
jeff64's Avatar
There is nothing behind those doors to set a battery on. That's where the Lp tanks sit... and you will want the 2017 model for the beefier axles and bigger tires and rims. With the VRL you will get a full size queen instead of a short one
2016 Flagstaff 27VRL Emerald
14K Equalizer
2014 GMC 2500HD CC 4X4 6.0L
Old 10-12-2016, 01:51 PM   #8
VaJim
battery
Remove your battery and have a plate welded on it an then reinstall batteries on it.
2010 Ram 1500 Quad 4X4 5.7L
2012 V-LITE 30WFKSS
VaJim is offline   Reply With Quote
Old 10-12-2016, 08:24 PM   #9
wbdavey's Avatar
X2 what Croaker said - see my signature below
2015 Rockwood Ultra Lite 2604 WS. Rear LR, large street side slide with small wardrobe slide in BR.
2014 Ram 1500 Eco Diesel Laramie Quad Cab.
wbdavey is offline   Reply With Quote
Old 10-12-2016, 09:08 PM   #10
gectisme's Avatar
We have a WJ but I would think it would be just about the same up front. Ours came with 2 batteries. There is a mounting plate bolted to the frame and 2 battery boxes.
ID:	122824   Click image for larger version
2016 Windjammer 3006WK
2010 Dodge Ram 2500, 4x4, Diesel, Front Hitch, Air Lift 5000 Rear Air Bags, (not really used, left over from our truck camper). Equalizer E4 1.4k/14k WD Hitch. TST 507 TPMS. Furrion FOS48TA Observation Camera. Garmin RV-760 GPS
gectisme is online now   Reply With Quote
