Old 08-26-2016, 01:01 PM   #21
Hi,
I have a TST 507 system, and tow a 36' Silverback behind a K2500 Chevy standard cab, standard bed with no repeater.
FWIW.
Rich Phillips
richp is online now   Reply With Quote
Old 08-26-2016, 10:53 PM   #22
Riverss
i also have the 507 and chose the type that you can check the psi and add abit without removing the TPS. i know lazy but tire pressures are critical imho.
2016 Rockwood 8299 BS
2015 Ram 2500 6.4L CC SB 3.73 posi 2X4
B&W Patriot 16K
Basenji back seat copilot named Lilly
riverss is offline   Reply With Quote
Old 08-26-2016, 11:25 PM   #23
gectisme's Avatar
I have rubber valve stems with the TST 507 Non-flow through. ~4000 miles so far and no issues and have not lost any air since I put them on back in April. One sensor has always read 3 psi lower than than the other 3 but I know it and compensate for it. I guess I should contact TST and get it replaced but being on the road makes that tough for shipping. I am running it without a repeater and have not lost signal as far as I know.
2016 Windjammer 3006WK
2010 Dodge Ram 2500, 4x4, Diesel, Front Hitch, Air Lift 5000 Rear Air Bags, (not really used, left over from our truck camper). Equalizer E4 1.4k/14k WD Hitch. TST 507 TPMS. Furrion FOS48TA Observation Camera. Garmin RV-760 GPS
gectisme is online now   Reply With Quote
Old 08-28-2016, 06:48 PM   #24
friendofacatahoula's Avatar
Thanks for the feedback. I will check on those ones mentioned.
Cheers
2015 MiniLite 2109S
2016 Ram 3500 6.7
friendofacatahoula is online now   Reply With Quote
Old 08-29-2016, 12:07 PM   #25
Originally Posted by richp View Post
Hi,
I have my TPMS system installed on stock rubber valve stems. For two years and many thousands of miles, I have had no problems.
However, I did install small dense foam collars around each stem, to reduce displacement from rotational forces that might eventually create a problem. And when I replace the tires I will change to metal stems, out of an abundance of caution.
FWIW.
Rich Phillips
Please tell more about the foam collars. Where'd you get them,. What did you make them out of, picture please
Thanks. Currently sweating the same dilemma. Hate to have a tire taken off rim and put back on if avoidable. Put hate to go too far on China bombs without my TPMS mounted.
Thanks Tom
Tom48 is offline   Reply With Quote
Old 08-29-2016, 01:21 PM   #26
Hi Tom,
Not near the trailer now to take pictures. Sorry.
However, what I did was take a piece of high density ethafoam, and cut it into sort of a small disk and made a hole in the middle that was slightly smaller than the valve stem. I shoved it over the valve stem until it was tight against the rim and then installed the sensor.
The effect I was looking for was to create pressure between the sensor and the rim, such that the valve stem would not be deflecting, moving and abrading against the rim -- particularly when the spinning wheel hit a bump. So far, so good...
Hope this helps.
Rich
Rich Phillips
2009 K-2500 Duramax
2014 Silverback 33RL
Old 08-30-2016, 02:18 AM   #27
Hi Tom,
Hope this helps.
Rich
Thanks RICH Torn between winging it and either replacing the stems or reinforcing. I guess they need balancing now that the rig as a few hundred miles so will see what they want to charge me for new all metal stems at that point and wither fix em or replace em before balance.
Tom
Old 10-20-2016, 01:43 PM   #28
Originally Posted by Handydc View Post
Any thoughts on what type of valve stems I should have on my TT tires to avoid problems with the external TPMS devices attached (see picture). I currently have the standard rubber valve stems. I've gone 2 years with no problems but don't want to invite problems.
Did you find a good metal stem? I have the same issues with the same wheels and cannot seem to find a good metal stem that the external nut and washer will fit in the angled section of rim.
2017 Rockwood MiniLite 2506S
2016 Chevrolet HC 2500 6.6L
bshort is offline   Reply With Quote
Old 10-20-2016, 06:09 PM   #29
I have the TST507 flothru-I did lot of looking & found a stem that was designed originally for an aluminum Ford dually-works purfectly for my use. I even called the manufacturer to discuss it with them. He even offered a little help that if I needed extra length because of wheel thickness the washer has a recess on one side that can be reversed giving more thread depth. If you get them you will understand. Dealer did not need to reverse it for my use. O'rielly auto parts have them, reasonably cheap. Their part # is 17-428 line code XTS
danandmillie is offline   Reply With Quote
Old 10-20-2016, 06:12 PM   #30
I forgot to mention I had to special order them. It took 1 day for me to get them. I ordered an extra one to have it if I ever needed it when on the road
