Old 05-29-2014, 08:36 PM   #1
vent hood damper
Went to use my vent hood for the first time. I can't get the outside damper open. It is the long horizontal vent. There is 2 "catches" on the bottom of the damper. I tried to open the damper by pulling down on the catches to release it but it does not open. The side of the catches look like they are attached like from the molding process. Can anyone confirm how the damper catches release the damper? Don't want to cut the sides if it doesn't work that way. Please help.
gserve is offline   Reply With Quote
Old 05-29-2014, 08:41 PM   #2
fonzie's Avatar
If you have same as shown, then use your thumbs and push up on the latches and pull outwards.
Fonzie
Old 05-29-2014, 08:43 PM   #3
bea60's Avatar
If its the same as mine, the catches tip to one side. Or pivot might be a better word. One goes left the other goes right. The tabs are attached from the bottom of them,where they pivot from. See if that works.
2015 Rockwood 2604WS
2008 Toyota Tundra CrewCab Limited
bea60 is offline   Reply With Quote
Old 05-29-2014, 08:43 PM   #4
Mine are like what fonzie showed. Use a thin bladed screwdriver or a table knife. I finally got mine open and left it unlatched. Been unlatched for 2 yrs now and it's still hanging in there.
Old 05-29-2014, 08:46 PM   #5
fonzie could you post the pic again I could not view it for some reason just a small white box was seen
Old 05-29-2014, 08:49 PM   #6
fonzie's Avatar
Posted again....are you on a smart phone or computer? sometime on smart phone picture does not show properly.
Fonzie
Old 05-29-2014, 08:52 PM   #7
Our clips did become a little easier to unfasten after a year.
Old 05-29-2014, 08:52 PM   #8
Using iPad still can't see it I'll try my laptop.
Old 05-29-2014, 08:59 PM   #9
Yes it's like the pic that Fonzie posted. Do you push up and and pull on the latches? Please explain further . Thanks
Old 05-30-2014, 05:49 AM   #10
Thanks to all that replied. Fonzie your description was spot on. Got it opened this morning. There was some caulking under the latches I had to get out first.
vent
