Old 10-13-2012, 06:28 AM   #1
Pug Dads
cheatham09's Avatar
Walls sweating
Spending the weekend close to Dan River, NC. Temps down to 39. Ran gas heat and walls sweating in certain areas. We have a 2013 3008 windjammer. Any suggestions to prevent this?
cheatham09 is offline   Reply With Quote
Old 10-13-2012, 07:04 AM   #2
I have found this to happen to. Windows sweat too. I'm told it is a normal occurrence. I just ordered a mini dehumidifier for my camper. I'm told that should do it.
Tarcon is offline   Reply With Quote
Old 10-13-2012, 07:36 AM   #3
Pug Dads
cheatham09's Avatar
What brand and model and where did you order. Thanks for the advice.
Old 10-13-2012, 08:52 AM   #4
lindy's Avatar
Easier solution is to leave one of your roof vent covers open about 1/2" this will help with air circulation which cuts down on moisture. Another factor in moisture build up in a camper is using the stove top or oven without running the hood exh vent, this will pull a lot of moisture out of the camper when cooking. Propane burners cause a lot of moisture build up in a confined space. I also use aa small elect space heater instead of the furnace. The space heater really dries up the air, and the fan circulates the air inside the camper.
2012 Winnebago "Journey To Insanity" 40U
2008 Dakota Sport 4x4
2004 Subaru Baja - DW's
2006 Honda Shadow Aero - TOAD for now.
F.R.O.G. member
lindy is offline   Reply With Quote
Old 10-13-2012, 09:33 AM   #5
bikendan's Avatar
air movement is the key.
if you close up your RV tight, when it cold and run the furnace with humans breathing inside, condensation going to form.
we crack a vent and window so that air can move.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 10-13-2012, 10:58 AM   #6
Hob
We wintered in Idaho last year. Went to a GE 30 pint per day dehumidifier. We now keep it in the trailer year round and if we are in the trailer the dehumidifier is on. I am convinced running it as much as possible keeps many of the dampness problems down. Of course, we use our trailer a lot so we may have more condensation than other people using theirs only on weekends.
Hob is offline   Reply With Quote
Old 10-13-2012, 11:26 AM   #7
Iggy's Avatar
X2
Iggy is online now   Reply With Quote
Old 10-13-2012, 11:38 AM   #8
Keep roof vents cracked and a window, this promotes venting of water vapor from your bodies, cooking, and breathing. A dehumidifier works well but take up space if that's at a premium like us.
mwebber78 is offline   Reply With Quote
Old 10-13-2012, 01:54 PM   #9
Old Member
mikey's Avatar
Send a message via Skype™ to mikey
New trailers tend to be tight so that a window needs to be open when the heater runs and to prevent condensation from forming on the walls & windows.
Drivin, Miss Daisey & the boss, Toppi
2018 Berkshire XL40B-380, SFE=244
mikey is offline   Reply With Quote
Old 10-13-2012, 07:08 PM   #10
Sunpentown SD-350TI $61 on Amazon
