Old 11-10-2012, 01:03 PM   #1
Wardrobe slide not working and front legs Help
Hello my Rockwood 8280ws 2012 Model the wardrobe slide will not come back in the switch is fine as we changed the switch from the living room slide and the switch worked the living room slide fine, and the front legs won't work we have had the battery box out looking for the fuses but we cannot find them, we have frond a switch with a 70 amp fuse we have pushed this in but nothing, can anyone help.
Thanx Tracy
tracybet is offline   Reply With Quote
Old 11-11-2012, 02:02 PM   #2
Jmjtx's Avatar
Thanx Tracy
I blew a fuse while setting up last summer. I think you are on the right path looking for the fuse. I don't own your model and if another member does not answer your question I would call the RV dealer and ask them how to troubleshoot the wardrobe slide.
Jmjtx is offline   Reply With Quote
Old 11-11-2012, 03:46 PM   #3
Hello well found the fuses behind the battery box in the front compartment with a really tiny button to press so all is working now
