Old 04-06-2015, 06:47 PM   #1
Waste water holding tank leaking
Help, we have a 2005 Rockwood that all of a sudden is leaking either black water or grey. I'm not certain which one is the culprit because they both drain out of a common outlet. I'm just wondering how much of a problem it would be for me to replace the valves my self. It may be too much, but then again it'd sure save a 100 mile trip to the dealership.
asmfmjb is offline   Reply With Quote
Old 04-06-2015, 06:53 PM   #2
You say a tank is leaking but you say you want to change a valve. What is actually leaking, the tank or the valve?
Old 04-06-2015, 06:54 PM   #3
Ford Idaho's Avatar
Are you sure there is not some debris holding the valve open a little?
Some have reported finding the plastic slug from a hole saw used to cut a in/outlet hole.
Old 04-06-2015, 08:17 PM   #4
Left Coast
Food coloring into 1 tank...or Green colored anti-freeze
Old 04-06-2015, 08:23 PM   #5
Put some water in the tanks and cycle the valves a couple times. If it still leaks, then you've got a bad valve.
2011 Traverse LT, 3.6L, FWD
leak, tank, water
