Old 06-27-2011, 01:09 AM   #1
Water
So we went to our favorite Provincial Park this weekend for the first trip of the year. Had a great time inspire of the rain. My problem is there was a boil water advisory so can any one make a recommendation on the best way to sanitize my fresh water tank?
Fireman2 is offline   Reply With Quote
Old 06-27-2011, 01:27 AM   #2
2Susan's Avatar
Bleach
Do you know what the advisory was for? If they had been doing work on the system there might have been mud in the lines and just as a precaution would have had a boil advisory. On the other hand if they've detected bugs, ghardia or crypto, you might want to go a little further to make sure your tank and lines are clean. If so, i'd shock the tank (meaning heavy dose of bleach). let it stay overnight, drain, rinse with known good water, drain, fill with good water, shock again, drain, rinse and fill with good water.
2011 Georgetown 320DS new June 2010
days camped in 2010: 61
days camped in 2011: 37 (up to Aug 1st)
2Susan is offline   Reply With Quote
Old 06-27-2011, 05:52 AM   #3
Did you use the tank or did you have full hook-ups? If you had hook-ups, and used the "city" water connection, you didn't put any of that water in the tank. In that case, you would only need to flush the lines.
LadyWindrider
2012 Ford F250 ext. Cab 4x4
2002 Jeep Wrangler Sahara
2008 Work and Play 18LT
Old 06-27-2011, 06:27 AM   #4
Fire Instructor's Avatar
1/4 cup of bleach per 15 gallons of water.
Fill water tank to top.
Run water out of every faucet, hot and cold (until you smell bleach)
Guestimate amount of water needed to refil.
1/4 cup of bleach per 15 gallons of water to be added.
Refill water tank to top.
Let sit at least 3 hours.
Drain system.
Refill with fresh water from reliable source.
Flush all faucets, lines, etc.
Let sit at least 1 hour.
Flush.
Repeat flushes until bleach smell gone.
I do this at least once per season. I try to get it done before my fist trip of the season, but this year it waited until after I got back from the first trip. (I wasn't using any tank water, as I was "camping" at a nice RV resort (Turning Stone Cassino RV Village), which has very reliable water system.
Fire Instructor
2014 RAM 2500 Laramie 4x4 Quad Cab w/Cummins Turbo Diesel, 2009 Rockwood 2607, and 3 'yaks!
300W of Suntech Solar, a Rogue MPT-3024 Controller, and a Xantrex PW2000 Inverter
Fire Instructor is offline   Reply With Quote
Old 06-30-2011, 05:21 PM   #5
No hook ups
