Old 10-03-2016, 09:53 AM   #21
Klbrown53's Avatar
I appreciate the concern and the advice everyone has given me. I am thick skinned enough to be able to except it when someone tells me "that's a stupid thing to do." Since I found no check valve or anyway to do a reset on the anti-freeze Inlet it was an attempt to get me through the next two days of camping. Disconnecting and reconnecting the water hose at the last campsite eventually did something that allowed me to finish our camping there. So, I thought I would give it a try. I was aware that the anti-freeze inlet was not designed to have city water hooked up to it but I only turned the water on for about two seconds and then immediately turned it back off.
Also be aware that after removing the under cabinet water filter I only have one valve left and it is a two position valve. Operate the valve to the other position when hooked up to city water and as someone else stated water goes into the freshwater tank. I feel like I have pretty much proven that the issue is the water pump itself. Most likely as everyone else has stated a check valve. That's the direction I'm headed to on troubleshooting at least.
If anyone else thinks of something else please let me know. I appreciate everyone's input.
Ken
Klbrown53 is offline   Reply With Quote
Old 10-03-2016, 10:14 AM   #22
Klbrown53's Avatar
Name:	ImageUploadedByForest River Forums1475503707.421456.jpg
The pump and single two position valve I have. The hose from the back side of the pump and valve comes from the anti-freeze inlet.
Name:	ImageUploadedByForest River Forums1475503964.846265.jpg
And the hose from the front part of the pump feeds freshwater to the rest of the RV.
At least that's the way I think it all works.
Old 10-03-2016, 10:17 AM   #23
bubbles's Avatar
When my water pump was leaking back into my holding tank when connected to shore water I switched over to the AF hose pump input and pinched off the AF hose. This kept the holding tank from being filled with shore water as the water was directed to the AF pinched off hose (no leaking). I did this as an interim to repairing my water pump when at home and so I could complete my camping trip without issue.
Old 10-03-2016, 10:56 AM   #24
One of these would probably work, too.
1988 Coleman Sequoia - popup (1987-2009)
2012 Roo19 - hybid (2012-2015)
2011 Traverse LT, 3.6L, FWD
2009 Silverado Ext Cab, 5.3L, 4x4, 3.73
rockfordroo is online now   Reply With Quote
Old 10-03-2016, 11:03 AM   #25
Klbrown53's Avatar
Rockfordroo,
I tried a temp fix using this on the AF inlet and it forced water into the fresh water tank.
Name:	ImageUploadedByForest River Forums1475506921.483069.jpg
Old 10-03-2016, 11:07 AM   #26
bubbles's Avatar
Yes it would if one has a fitting in that path to screw into. I don't, thus, the pinched tubing. Crimp at valve and open ended AF tube.
Old 10-03-2016, 11:16 AM   #27
Originally Posted by Klbrown53 View Post
Rockfordroo,
Attachment 122045
If it did, then either you didn't have the 3-way valve fulling turned to the AF position, or the 3-way valve was leaking by.
Old 10-03-2016, 11:18 AM   #28
Klbrown53's Avatar
Rockfordroo,
Remember, no three-way valve on mine. It's a two way valve. Antifreeze inlet is either open or closed.
Old 10-03-2016, 11:52 AM   #29
bubbles's Avatar
Rockfordroo,
So is the 3 way valve (mine is also a 2 way). You apparently have 2 issues. A bad pump (allowing backflow) and a bad AF holding tank selector valve (allowing cross feed between tank and AF hose). I'm done.
Old 10-03-2016, 12:03 PM   #30
Klbrown53's Avatar
Thx all for everyone's input!!!!
water
