Old 06-04-2014, 05:56 AM   #11
Hoo Dad's Avatar
Originally Posted by KathyEd View Post
We just got our 8289ws and so far love it. Any helpful hints on the water filter? I am having trouble removing the casing to put the filter in. It isn't in the most convenient place to get a good grip on it.
I finally got tired of changing the water filter in the tight cramped space and removed the filter. I now use an outside water filter, purchased from wal-mart, and replace every few months of use. Eventually I by-passed the canister and completely removed it.
If you continue to use the inside water filter, use food grade silicone grease. As stated earlier this can be found at most hardware stores. Petroleum jelly (Vaseline) is not recommended.
2011 Rockwood 8285 WS
2011 GMC 3500 HD 4X4, 6.0, 4.10, SRW
Hoo Dad is offline   Reply With Quote
Old 06-04-2014, 06:38 AM   #12
I always have a tube of Magic Lube around for orings. You can get it online or pool supply stores.
I tossed the original POS filter assembly and installed one that uses common 10" filters. The filter housing comes off easily with one hand and was able to properly secure the entire assembly unlike how the original was mounted.
2014 Georgetown 351DS
-TruCenter -Front/Rear CHF -Hellwig Links -Tiger Trak -Ran McNally GPS -ScanGauge -Truck Systems TPMS -5 Star Tune
alparmer is offline   Reply With Quote
Old 06-04-2014, 06:48 PM   #13
PhoneDude 8289's Avatar
Be sure pressure is off the system. Water pump off, city water off and open faucet to relieve pressure. Things come apart allot easier.
Joe & Beverly
2014 Ram CTD, CC, SB
2014 8289WS lifted
PhoneDude 8289 is offline   Reply With Quote
water, water filter
