08-08-2014, 07:45 AM
Water Filter
This may be old news to some but I just discovered the hidden water filter in my 8289 is only connected to the cold water side.
I was about to spend big $$ to replace when I caught it. I flushed the cold water for 30 seconds or so to get the chlorine out of the lines and, voila, fresh tasting water.
The filter is by WaterPur and so far does a good job cleaning out the bad taste.
Ken
08-08-2014, 08:20 AM
Checked my 8280 and it's the same--just cold water filtration. Good to know, but likely won't change how we use our water. We bring along purified water for drinking. I guess the point of only filtering cold is making it taste good and be safer for drinking.
I change my filter yearly regardless of usage. I find my dealer price of $20. reasonable. Actually, any thing purchased there (Wana RV in Shipshewana, IN) is always reasonable, from Honda generators to hose end fittings.
2014 Rockwood 8280WS
2010 Tundra 5.7 Dbl Cab 4x4
08-08-2014, 08:29 AM
If the water is filtered before going into the water heater there would be no need to filter it again.
The factory filters I have seen are before the fresh water tank.
08-08-2014, 09:14 AM
AKA: 'tiredTeacher
My TT (2604WS) has the water filter on the inlet side of the entire water system. Water goes from either on-board tank or city inlet, through the filter, then splits to the heater and cold side supply.
Wright and Penny
(with Fitz and Lizzie, the camping kitties)
Richmond, Va.
2010 Tundra 4X4 5.7L V8
2014 Rockwood 2604WS
Life is a cruel teacher. She gives the test first; the lesson then follows.
08-08-2014, 09:58 AM
Owner/Operator
^ X2
The entire system is filtered, both hot and cold.
However, not wanting to hassle with changing the filter which was behind the storage compartment wall, I bypassed it an now use dual external filters on the City Water Supply.
The only downside to this is that when using the pump and water from the Fresh Water Holding Tank is does not pass through the filter. HOWEVER, I filter the water that is put into the Fresh Water Tank as I fill it.
RodeoGeorge
2013 Rockwood 8289WS
Mods: Central Vac, PI EMS-HW50C, 2025RV, (2) SCS225 Trojans, PD9260, Awning Remotes & LED Lights, Eliminators, External Water Filter,, Intellijacks
2008 RAM 3500 Cab&Chassis Hauler Bed, B&W Companion Hitch
All My Modifications are at this link:
https://www.forestriverforums.com/for...ons-36212.html
08-08-2014, 09:59 AM
I was surprised to find only cold water filtration. That's why I wanted to alert those that may have the same situation.
Ken
08-08-2014, 11:33 AM
Ken
Hmmm.... Are you sure?
I assumed that all trailers had the filter at the intake after the tank and it fed to the cold pipes and water heater from there. That's how mine is. Is your filter right by your pump?
08-08-2014, 12:18 PM
i just removed my inline water filter in my Flagstaff version of the Rockwood 2109s. The water filter is before the Hot Water split so all water is Filtered
2015 Ram 2500 4x4 6.4l with 2015 Sandpiper 25RLS
Wife, myself and 2 furry kids
08-08-2014, 12:20 PM
Owner/Operator
Ken
Ken, just for clarification in the event that you have an additional filter under your kitchen sink for the cold water tap, where is the "hidden water filter" that you're referring to located?
Is it behind one of the walls in the understorage area, or is it under the sink or elsewhere?
RodeoGeorge
08-08-2014, 03:18 PM
I used the term "hidden" but only because it's enclosed behind a door with hinges on both sides. It's next to the pump and water heater.
09-17-2014, 12:31 PM
23ss ROOster
Mine was behind this same door with hinges on both sides, preventing access into this area. I removed one side of hinges and use it now as a door, easily able to get into this area for access to water filter, water heater, and water lines. Why does Rockwood put double hinges on these doors in production?
2012 23SS ROO
2014 Ford 4x4 F150 XLT 302A, screw, Ecoboost, 3.73, max tow, off road pkg., 36 gal tank, Ruby Red, tailgate step, Linex spray in, Truxedo bed cover, 30% front tint, Viper remote start, 1000 lbs WDH
09-19-2014, 07:16 AM
I was told not to drink water from a CG even with a Camco inline water filter, just wondering if anyone does? We bring filtered water from home
2016 F350 Supercew Short Box 6.7 PowerStroke Diesel
2013 Crusader 295RST Touring Edition
09-19-2014, 08:34 AM
I bypassed our water filter last year after a slow leak on the input side, and the hassle of trying to winterize with the canister in place. We drink only bottled or filtered water from home, so having a near unaccessible water filter is an unnecessary part in our camping world.
Cheers from Alberta Canada
2011 Flagstaff 8526RLWS 5th Wheel
2011 Ford F250 4X4 Crewcab Superduty 6.7L Diesel
B&W 3300 Hitch for Ford 5th Wheel Prep package
09-19-2014, 09:24 AM
I use one of these just not to contaminate my Rv tanks and smells of CG well water, works perfect and you can't beat $10 per unit per season price
09-19-2014, 09:39 AM
Attachment 63065
I also use one of these, along with the built in filter. We have had no issues drinking or cooking with the CG water.
Bill & Pam
2014 Trilogy 3650RE
2015 F350 PSD
09-20-2014, 10:31 AM
Next season I am switching to this one just because I can put this under my kitchen sink and have it mounted
09-20-2014, 10:40 AM
Attachment 63065
Where can we buy these (Blue Inline Fiters) for 10.00$? Youroo!! For that price I would use one on the hose that I Wash the (Truck/Camper) with!
09-20-2014, 10:52 AM
They are all sold on Amazon I bought a 4 pack for $40 but not the inline ones they tend to be slightly more
09-20-2014, 10:59 AM
The one in your (Post#14) looks like a (Inline) if not how does it Work? Youroo!!
09-20-2014, 11:37 AM
Twenty one dollars for a 2 pack at walmart
Jay & Maria - Camp Dog Joplin
2018 Cedar Creek Champagne 38EL
Fulltimers since May 2018!
2017 Ford F350 Crewcab Dually Diesel
Officially homeless and loving it.
Ham Callsign K9NDY
