Old 08-08-2014, 07:45 AM   #1
Water Filter
This may be old news to some but I just discovered the hidden water filter in my 8289 is only connected to the cold water side.
I was about to spend big $$ to replace when I caught it. I flushed the cold water for 30 seconds or so to get the chlorine out of the lines and, voila, fresh tasting water.
The filter is by WaterPur and so far does a good job cleaning out the bad taste.
Ken
TheBennetts is offline   Reply With Quote
Old 08-08-2014, 08:20 AM   #2
Checked my 8280 and it's the same--just cold water filtration. Good to know, but likely won't change how we use our water. We bring along purified water for drinking. I guess the point of only filtering cold is making it taste good and be safer for drinking.
I change my filter yearly regardless of usage. I find my dealer price of $20. reasonable. Actually, any thing purchased there (Wana RV in Shipshewana, IN) is always reasonable, from Honda generators to hose end fittings.
2014 Rockwood 8280WS
2010 Tundra 5.7 Dbl Cab 4x4
ronb707 is offline   Reply With Quote
Old 08-08-2014, 08:29 AM   #3
Ford Idaho's Avatar
If the water is filtered before going into the water heater there would be no need to filter it again.
The factory filters I have seen are before the fresh water tank.
Old 08-08-2014, 09:14 AM   #4
AKA: 'tiredTeacher
awellis3's Avatar
My TT (2604WS) has the water filter on the inlet side of the entire water system. Water goes from either on-board tank or city inlet, through the filter, then splits to the heater and cold side supply.
Wright and Penny
(with Fitz and Lizzie, the camping kitties)
Richmond, Va.
2010 Tundra 4X4 5.7L V8
2014 Rockwood 2604WS
Life is a cruel teacher. She gives the test first; the lesson then follows.
awellis3 is offline   Reply With Quote
Old 08-08-2014, 09:58 AM   #5
Owner/Operator
RodeoGeorge's Avatar
^ X2
The entire system is filtered, both hot and cold.
However, not wanting to hassle with changing the filter which was behind the storage compartment wall, I bypassed it an now use dual external filters on the City Water Supply.
The only downside to this is that when using the pump and water from the Fresh Water Holding Tank is does not pass through the filter. HOWEVER, I filter the water that is put into the Fresh Water Tank as I fill it.
RodeoGeorge
2013 Rockwood 8289WS
Mods: Central Vac, PI EMS-HW50C, 2025RV, (2) SCS225 Trojans, PD9260, Awning Remotes & LED Lights, Eliminators, External Water Filter,, Intellijacks
2008 RAM 3500 Cab&Chassis Hauler Bed, B&W Companion Hitch
All My Modifications are at this link:
http://www.forestriverforums.com/for...ons-36212.html
RodeoGeorge is offline   Reply With Quote
Old 08-08-2014, 09:59 AM   #6
I was surprised to find only cold water filtration. That's why I wanted to alert those that may have the same situation.
Ken
Old 08-08-2014, 11:33 AM   #7
Ken
Hmmm.... Are you sure?
I assumed that all trailers had the filter at the intake after the tank and it fed to the cold pipes and water heater from there. That's how mine is. Is your filter right by your pump?
2011 F150 SuperCrew 5.0 4x4
2012 Flagstaff 27BESS
pappcam is offline   Reply With Quote
Old 08-08-2014, 12:18 PM   #8
i just removed my inline water filter in my Flagstaff version of the Rockwood 2109s. The water filter is before the Hot Water split so all water is Filtered
2015 Ram 2500 4x4 6.4l with 2015 Sandpiper 25RLS
Wife, myself and 2 furry kids
Mountndream is offline   Reply With Quote
Old 08-08-2014, 12:20 PM   #9
Owner/Operator
Ken
Ken, just for clarification in the event that you have an additional filter under your kitchen sink for the cold water tap, where is the "hidden water filter" that you're referring to located?
Is it behind one of the walls in the understorage area, or is it under the sink or elsewhere?
RodeoGeorge
Old 08-08-2014, 03:18 PM   #10
I used the term "hidden" but only because it's enclosed behind a door with hinges on both sides. It's next to the pump and water heater.
water, water filter
