Old 10-13-2014, 08:35 PM   #11
I removed ours this week after having the camper 2 days after reading here.
emt676 is offline   Reply With Quote
Old 10-13-2014, 08:39 PM   #12
Now I just need to relocate my water pump that is next to where it was and I'll free up a lot of storage space.
2016 Flagstaff 27VRL with overloaded tires from factory
2015 Chevy Silverado
Paul GA is offline   Reply With Quote
Old 10-14-2014, 01:05 PM   #13
Hey Guys, I have a dumb question.
I have the same filter in my Flagstaff and have not had a problem during my first season. (I know, it’s just a matter of time.) Why not just run a strip of duct tape around the joint between the clear container and housing? There can’t be that much force trying to unscrew the container. Or if you really want to secure it, attach the filter wrench and zip tie that to something so it can’t turn.
I agree that changing it is probably best, but I have a couple of expensive extra filters that I plan on using next season.
2017 Sunseeker MBS 2400R
llberge is offline   Reply With Quote
Old 10-14-2014, 01:10 PM   #14
You could take it out, screw in a couple pipe thread/hose thread adapters to it and use it outside with the stand Ford showed. Just not worth the risk of water damage, at least that's my opinion... But I'm hardly ever right lol..
Old 10-14-2014, 01:15 PM   #15
Originally Posted by WFD View Post
Or just use Shark Bites...work very slick...the way the plumbing is on alot of these RV's, you will be very challenged to get a crimper into alot of those tight places, let alone having room to work.
I think i have read on here that Using Shark Bites is a NO NO. The constant vibration of road travel can cause them to loosen/ leak. It passes the common sense test to me
2015 Ram 2500 4x4 6.4l with 2015 Sandpiper 25RLS
Wife, myself and 2 furry kids
Mountndream is offline   Reply With Quote
Old 10-14-2014, 01:22 PM   #16
TURBS's Avatar
I've had shark bite fittings on my trailer since 2011.
No leaks here!
Turbs
Old 10-14-2014, 01:28 PM   #17
Not saying I am in anyway an expert on this, just something I recall reading and why I went with Cinch clamps. It was so easy even i can do it.
If you have been using it for over 3 years, sounds like it works well enough.
Old 10-14-2014, 01:35 PM   #18
TURBS's Avatar
I was giving you a hard time nonetheless!
They hold up superior to vibration!
User installation error is more common.
Ends cut crooked.
Jagged cut ends.
Smashed hose.
Etc etc etc
Turbs
Old 10-14-2014, 04:03 PM   #19
ColoradoRick's Avatar
Okay now I'm scared...taking off that water filter ASAP...
Rick & Karen
(Retired USAF, MSgt)
Monument, Colorado
6-year Travel Trailer RVers
2013 Forest River Rockwood Ultra-Lite 2904SS
2014 Toyota Tundra Maxcrew SR-5 TRD 4x4 (with Firestone airbags in the rear)
ColoradoRick is offline   Reply With Quote
Old 10-14-2014, 04:21 PM   #20
Not sure if this will help... But had a similar issue with my whole house filter..I would tighten and a few weeks later would be leaking... Called plumber that installed it.. Figure it should still be under warranty...He explained that I should lube the o ring... Otherwise I would be over torque the filter distorting the O ring.. And the o ring itself would loosen the filter when the pressure dropped... ...didn't believe him so tightened and marked the canister with when fully tightened..and within a few hrs noticed the lines no longer matched up.( filter was unscrewing)So I removed and lubed oring and hand tightened... Sure enough it never moved again...So know every time I change the filter I lube the o ring..
Same thing happened with MH.. It would just leak for a second anytime pressure changed....So removed and lubed O ring... No leaks...hope this helps
Good luck
2010 Georgetown 300FWSSouth Florida
speedjester is offline   Reply With Quote
water, water filter
