Old 05-06-2012, 12:25 PM   #11
Originally Posted by annamarie View Post
We've always left the rod in, with the switch off and after water is drained, in between our camping trips. Have we been doing this wrong? Why does the rod need to be removed when not in use? It just seems easy to keep it stored there, 'til we go camping again.
I agree, see no reason to remove it after each use. I check it once a year to see if it needs replacing. Other than that, I think it is just a waste of time to remove it multiple times a year. We don't empty the wh either, just turn both systems off and leave it alone til we use the camper again. We just treat it like the one at home with the exception of checking the anode once a yr.
Old 05-06-2012, 12:50 PM   #12
papap's Avatar
I agree. You do not drain the one in your house. I pull plug and rinse the tank once a year.
2016 Forester 3171DS
Work 28 and 28 around the world.
Camp every chance we get
papap is offline   Reply With Quote
Old 05-06-2012, 01:15 PM   #13
Playtime III
Playtime III's Avatar
During winterization, remove the anode. This will drain the tank and at the same time you can inspect for corrosion (particles flowing out when the tank is almost empty) and anode condition.
Our second winterization, I had issues with both so I bought a new anode (already had some teflon tape) and a flusher wand (looks like a 1' water pic that screws on to the hose). I gave the tank a good rise at winterization and again at de-winterization, installed the new anode and filled the tank via the city water connection (be sure to let the air escape via the overtemp valve). If I left the particles in the tank, it could get trapped in the overtemp valve and it will leak or get pushed down stream in get trapped in the sink faucet's screens.
Playtime III
TT 2011 2902SS
TV 2007 F-150 SC 4x4 5.4
800 wd/dual cam sc
Playtime III is offline   Reply With Quote
Old 05-07-2012, 05:35 PM   #14
rossandjan's Avatar
We turned the gas off but never did get hot water with the electric turned on. Since we were at the beach we didn't feel like messing with it anymore and figured we would check it out at home. Any idea what we should check for.
RossandJan
2012 Rockwood 8314BSS
2006 Chevy 2500 HD 6.0 gas 4x4
Ross - Letter Carrier (retired 2011), Jan - YNC(retired 1996)
Nights Camped 2011 (8)
rossandjan is offline   Reply With Quote
Old 05-07-2012, 05:43 PM   #15
TURBS's Avatar
altho others have stated leaving anode rod in and not draining hw tank if you happen to put in water that is high in sulfur which most ground wells do you may get a rotten egg smell if not drained and left to sit .
WE drain our hw tanks after each use and have no rotten egg smell and not lime scale deposit issues in the water system . just something to think about .
Old 05-07-2012, 05:52 PM   #16
Rebel702's Avatar
You do need shore power for electric. WH does not run off battery.
Rockwood Windjammer 3002W (11/10/2011)
2011 Sierra Denali HD - Duramax/Allison
EQ-4, 14,000/1,400
2006 Yukon Denali
Rebel702 is offline   Reply With Quote
Old 05-07-2012, 05:57 PM   #17
TURBS's Avatar
Originally Posted by windrider View Post
The switch for the electric is outside, behind the water heater cover, lower left. If you are plugged in, and the heater is full of water, and sounds like it is, just turn the switch on outside. Make sure you DO NOT....DO NOT... turn on the inside switch with the red light. That switch controls the gas operation only. Also make sure you turn off the electric before you unplug.
this is not necessarily true anymore .
my switch on my hw heater has been disabled and the gas and electric switches are both inside .
Old 05-07-2012, 06:37 PM   #18
Hoo Dad's Avatar
You may want to check the HW heater breaker inside the camper to be sure it hasn't tripped. If still no hot water and you are able to use a voltmeter then check to be sure you have power to the heating element. If you do have power you then need to ohm the element to see if it is shorted. If so, then you will need to install a new element.
2011 Rockwood 8285 WS
2011 GMC 3500 HD 4X4, 6.0, 4.10, SRW
Hoo Dad is offline   Reply With Quote
