Old 09-01-2010, 04:12 PM   #11
samsc03's Avatar
I wondered this also. I tried it our first time out and the gas was still burning also. So I assumed that the LP must be closed for that to work on electric only. Is that correct?
Sam and Tonya
2011 Shamrock 19
2003 Toyota Tacoma V6 4wd
Tekonsha Voyager
Equal-I-zer
samsc03 is offline   Reply With Quote
Old 09-01-2010, 04:29 PM   #12
Dave_Monica's Avatar
Sam and Tonya
You only need to shut off the water heater switch (usually red and lighted) located in the control center between the water pump and tank heater switches. That controls the propane heater portion only.
Dave
Old 09-01-2010, 04:45 PM   #13
The gas system and the electric system are both completely independent of each other. You can run both at the same time, for quicker recovery(6 gallon tank X how many people?) If the gas is on, you merely have a lighted rocker switch for gas operation, (which will cycle on and off, as temperature requires). For electrical side, switch outside under the access door cover must be on, as well as the circuit breaker on the converter. Hope this helps! Randy
Old 09-01-2010, 06:04 PM   #14
has anyone came up with a mod to install a switch inside to operate the electrical side of the water heater. Would sure beat going outside to turn off and on. Also the latch for the WH cover would receive less wear.
kscr4 is offline   Reply With Quote
Old 09-01-2010, 06:34 PM   #15
The Old Man
Willis's Avatar
It's on my to-do list. Will take pictures, but not sure exactly when I will get it done.
2010 Flagstaff 829RGSS
Still to go: AK, NL, NT, NU, YT
Willis is offline   Reply With Quote
Old 09-01-2010, 06:43 PM   #16
Iggy's Avatar
You can turn the breaker on insude thw water heater and use the 15 amp circuit breaker to turn ON and OFF.
Iggy is online now   Reply With Quote
Old 09-01-2010, 06:55 PM   #17
samsc03's Avatar
thanks appreciate the tip.
Sam and Tonya
2011 Shamrock 19
Tekonsha Voyager
Equal-I-zer
Old 08-04-2011, 08:19 AM   #18
Any problem with leaving the electric element on all the time while camping? Assume it is AC only?
jacksum2 is offline   Reply With Quote
Old 08-04-2011, 02:35 PM   #19
I installed a combo switch/neon light below the sink on my 2012 2608SS to control the WH, ran 3 conductor romex from the sw/light to the breaker box and made the connections to the breaker and WH there. Works great, the light is on when the heater is on, never have to go to the water heater to turn it on.
Also added an additional 15A GFI circuit to the same location, there is only one 15A GFI circuit to the entire trailer. We sometimes have a coffee pot, toaster and fry pan going and were having occasional nuisance trips.
camper1953 is offline   Reply With Quote
Old 08-04-2011, 04:28 PM   #20
buckisland1950's Avatar
You can leave the switch on while camping the heater will just cycle on and off keeping the water hot. Just be sure to remember to turn it off when leaving the campground or if you don't and plug in with no water next time you will burn the element out....
2011 F250 Lariat Crew Cab 6.7L Diesel
2011 Flagstaff Classic Superlite 831 FKBSS
Fleet of Canoes and one Kayak
So Many Rivers so Little Time!
buckisland1950 is offline   Reply With Quote
rockwood
