Originally Posted by Skip12
While you wait for a better answer, I'd look under the sink if I were you. Are there any acess panels to get under the sink or maybe a silverware drawer than can be pulled out? Hope that helps.
There are no removable panels. I can't figure out how to get the drawers out of their slide rails. However, I can see behind all 3 of the drawers under the sink and there is no sign of any water lines and that area is a good distance from the rear side of the water heater.
I called Forest River and the tech person that I talked to couldn't give me a definitive answer. All he said was the by-pass valves had to be very near the backside of the water heater which I knew was the case. Directly behind the water heater is the AC breaker panel and the 12 volt fuse panel and small wood panels that have no visible way to be removed.
I was a bit taken aback by the gentleman at the factory not having any precise reference as to access the by-pass.
