Old 07-22-2016, 10:25 AM   #1
Water heater bypass on 8325SS
Ok, I give up! I have searched all around the oven and sink area and cannot find an access panel for the water heater bypass. Please help before I break something.
bkool2323 is offline   Reply With Quote
Old 07-22-2016, 10:32 AM   #2
The bypass valve will most likely be near your hot water heater.
Trevor43 is offline   Reply With Quote
Old 07-22-2016, 10:43 AM   #3
fonzie's Avatar
Could it be behind the door next to your couches in kitchen counter....might have to remove a panel inside or would be behind the kitchen drawer (need to remove)...see index 10:40 on video....
Fonzie
Nights Camped: 2011(21) 2012(36) 2013 (17) 2014 (18) 2015 (18) 2016 (36)
Old 07-22-2016, 11:05 AM   #4
Flybob's Avatar
Find the water heater on the outside of the trailer. The bypass will be behind it. You need to access from inside most likely behind a panel or false wall in a storage space.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 65W solar panels
Old 07-22-2016, 11:49 AM   #5
FR likes to make cabinet doors that don't open. Instead of a knob, there's a third hinge on the knob side. See left cabinet door in the pic below. They like to put things like HWH valves, slider controllers, etc. behind these. If you have one of these, take the screws out of the 3rd hinge and see what's behind it. Even if it's nowhere near your water heater, I'll bet there's something behind that door that you ought to know about.
2012 Roo19 - hybid (2012-2015)
2011 Traverse LT, 3.6L, FWD
rockfordroo is online now   Reply With Quote
Old 07-22-2016, 12:53 PM   #6
Must take out drawers to get to bottom and middle I just had camping world cut acceses door into Luther side of cabin rt not sure how it looks camper still in for work
RAYSR is offline   Reply With Quote
Old 07-22-2016, 01:33 PM   #7
I don't know why the FR doesn't put an access door for the WH bypass. The best way to find the access is to check where the WH outside panel is then check what is behind it on the inside. My last trailer it was just below the refrigerator panel outside. On the inside there was a slotted screwed in panel below the fridge. I had to unscrew the panel to access the bypass. In my first Trailer I had to saw a little door in the panel under the bathroom wardrobe.
Why don't they just make a door access?????
RitaB is offline   Reply With Quote
Old 07-22-2016, 01:52 PM   #8
JustJ's Avatar
We found ours below the oven door. It has a vent cover mounted on it. 4 little screws on the corner.
JustJ is offline   Reply With Quote
Old 07-22-2016, 02:03 PM   #9
SeaDog's Avatar
As is easy to see there is no standard placement or standard cover. I got lucky on my rig the water pump and all valves are in the same compartment. Good luck when you find it let us know where it was
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
AF&AM of Idaho
Old 07-22-2016, 04:56 PM   #10
Red face bypass
There should be a way in from the cargo area or in my case i had to take my steps apart going to the bedroom (fifth wheel by the way "Sabre"). It's also where i found the sub for the stereo system::
chilli is offline   Reply With Quote
bypass, heater, water, water heater
