Old 10-24-2012, 08:13 PM   #11
VinceU's Avatar
Originally Posted by mduff View Post
We've found that the water seems 'hotter' when running on electric; assume a different temperature setting. When we're connected to a 30A service I turn on the electric element for HW. As noted by Dave make sure your HW tank is full; I run the hot water faucet for a few minutes prior to turning the HW tank on (electric and/or propane).
Yes, Dometic sells the thermostat in 120, 130, and 140F temp settings in either the 12v (gas) or 120V elec thermostats.
Old 10-25-2012, 08:22 AM   #12
Lanningjw's Avatar
Maybe I should rethink the way we are heating the water with propane and think about using the 30A electric. I didnt know you could use both electric and propane for a quicker heat up.
We keep the Windjammer at a resort fulltime.
2012 Windjammer 3001W
2010 Roo 19 (traded in)Mustang pop up (Sold)
1,000/10,000 equalizer
2000 Lund fishing Boat/2005 King Ouad 700 ATV
Windjammer lives at a Resort in Northern Minnesota. Lots of walleyes!
Lanningjw is offline   Reply With Quote
Old 10-25-2012, 08:33 AM   #13
We only use the gas for dry camping or occasionaly when I need Hot water for clean-up at home. (Not enough 110V juice to power the WH and other stuff on that circuit.)
When we camped with the 3 daughters, we would also use the LP in combo with the electric for a faster recovery.
btw...check your WH LP burner tube often. I found some "bug life" in there this weekend. This is a very commmon cause for WH failure...at least on the gas side!
Cathy & Jeff
Midland, Michigan
2013 Sabre 32RCTS / 2012 Ram2500 Hemi
SimchaSabre is offline   Reply With Quote
2013 signature ultra lite, electric, monitor panel, propane, water heater
