Old 01-26-2014, 04:49 PM   #11
Capt. Mike's Avatar
Originally Posted by wmtire View Post
Mike, are you talking about the anode rod (1 1/16th) or the electric heater element (1 1/2") on the Suburban water heaters?
Here is a pic of them both:
The electric heating element has the two wires attached. The anode rod, is to the bottom right of it.
Ooops, my bad. Anode rod 1 1/16", electric heater element 1 1/2". I'm going stir-crazy and this is just one manifestation of it. C'mon spring!
Mike and Yvonne
and Sophie, the little white dog
2017 Columbus 320RSC
2015 Chevy Silverado 2500HD Duramax 4X4
It's not how old you are, it's how you are old.Jules Renard
"It's not the years...it's the mileage." - Indiana Jones
Capt. Mike is offline   Reply With Quote
Old 01-26-2014, 05:57 PM   #12
Reinstall with hardening Permatex - or teflon tape. Note that teflon tape will give you a false torque reading - if torque wrench says 60 you probably have 180lbs.
It's just pipe thread - 1/2 a turn past snug should do it - check it the first time you fire it up.
same thing I had - took the impact a bit to finally loosen it.
cadman99 is offline   Reply With Quote
heater, water, water heater
