Old 01-25-2014, 09:51 AM   #1
Unhappy Water heater element removal
I need to replace the electric element in our water heater (yes, you know what we did, HeeHee). We have the tool and the replacement part, but can not seem to break loose the original element. Any suggestions? Thanking you in advance.
Dwilki is offline   Reply With Quote
Old 01-25-2014, 09:56 AM   #2
wmtire's Avatar
Are you using the stamped metal element wrench that needs a T-handle, like below? If so, you might can get a longer screwdriver or rod to use as the handle...to get better leverage when trying to twist it.
You can usually get better leverage when using a true 1 and 1/2 inch six point socket designed for this purpose, with extension and ratchet or breakover bar........like below:
http://www.amazon.com/TEKTON-1828-2-.../dp/B000NPT5L2
2011 Flagstaff 831 RLBSS
Iíve lost my scapegoat.
Old 01-25-2014, 10:18 AM   #3
Capt. Mike's Avatar
Ours takes a 1 1/16" socket.
Mike and Yvonne
and Sophie, the little white dog
2017 Columbus 320RSC
2015 Chevy Silverado 2500HD Duramax 4X4
ďIt's not how old you are, it's how you are old.ĒJules Renard
"It's not the years...it's the mileage." - Indiana Jones
Capt. Mike is offline   Reply With Quote
Old 01-25-2014, 10:22 AM   #4
wmtire's Avatar
Mike, are you talking about the anode rod (1 1/16th) or the electric heater element (1 1/2") on the Suburban water heaters?
Here is a pic of them both:
The electric heating element has the two wires attached. The anode rod, is to the bottom right of it.
Old 01-25-2014, 12:14 PM   #5
Fine someone with a good 1/2" drive impact - it takes 30 seconds.
cadman99 is offline   Reply With Quote
Old 01-26-2014, 02:58 PM   #6
Mission Accomplished!!!
Thx WMTire and Cadman99!! We had an impact tool and the actual 1 1/2 socket did the trick!!!! Took all the impact tool had to break it loose. Does the replacement element need to be reinstalled that tight with 320 lbs of torque??? THANKS AGAIN!!!!!!!!!!!!!!!!!!!!!!!!!!
Old 01-26-2014, 03:08 PM   #7
Herk7769's Avatar
Could it be that the anode got used up at some point and the threads on the heating element got corroded? I have no idea why else that would be so tight!
HAM CALLSIGN - KC3FFW
Old 01-26-2014, 03:13 PM   #8
herk7769
This is a new Rockwood (camped one wk in it) and we were winterizing it and failed to turn the switch off. Never had an electric option before. Actually the element looks good. We just wanted to replace it knowing that we burned it up having the electric on and no water.
Old 01-26-2014, 03:42 PM   #9
Herk7769's Avatar
I guess King Kong works at the Suburban plant under an assumed name!
Old 01-26-2014, 03:47 PM   #10
B47
Either that or the factory torque wrench (s) need calibrating - this is assuming they use torque wrenches at the factory.
heater, water, water heater
