09-22-2015, 06:14 PM
Water heater general maintenance
Hi all,
Can't recall if this is even mentioned in the manual, but I've been draining the water heater and low point drains after each trip.
Question: Is it better to leave the annod plug out till next trip , and should I be rinsing the tank after each use ? Like to do whatever will increase the longevity of the tank.
09-22-2015, 06:34 PM
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
09-22-2015, 06:37 PM
H2oski
My HW stays full all season long. I drain the entire system when I winterize the camper.
Just MHO.
Wife
2007 Chevy 2500 HD 6.6
2012 Sabre 31RETS
(LA) Lower Alabama
09-22-2015, 10:39 PM
Hmm, guess it shouldn't matter then. I tend to over think things. Do you guys use a water softener ?
09-23-2015, 11:17 AM
W H maintance
Once a year to winterize
09-23-2015, 11:46 AM
WH Maintenance
I'm like the others. I drain the water heater once a year in the fall (as I did two days ago). We rarely use the fresh water but I do put several cups of bleach in it just before we leave for home on our last trip, then I drain the tank. I leave the anode out until we start camping again in the Spring.
09-23-2015, 12:20 PM
Location: Full timer,,,at Lake Georgetown in central Texas for the winter.
We're full timers and I drain the tank once or twice a year to clean out the solid debris that collects in the bottom. The rod stays until it's pretty much eaten up.....usually I replace it annually.
09-23-2015, 12:23 PM
Just make sure when you remove the anode, you smear some Danco silicone paste on the tank threads to prevent rust. Even after 40+ yrs with trailers, I forgot to do it when we came home from FL this year and had to "chase" the threads to get the anode back in. CRS strikes again.
09-23-2015, 12:28 PM
Yup,,,,I agree with the OldCoot. Teflon on the threads of the anode are also necessary. I had some friends who ignored theirs for a couple years. I thought they were going to rip off the threaded base trying to get the anode unloosened. BTW, Old Coot,,,,is Concord, NC in the Blue Ridge. My wife and I are going to be heading that way next spring for a park host gig.
09-23-2015, 12:39 PM
Thanks, OC, for the Danco silicone paste tip. Hadn't heard about this. Should make life easier next spring. Assume I can purchase at the hardware store.
2015 Shamrock 23IKSS, Oyster shell
2019 Chev Silverado LT Z71 Ext. Cab, 4x4, 5.3L V/8
Reese Straight Line WDH, 2000W Honda Gen.
2 Old Town kayaks & 2 Boston Terriers - Zoey/Gonzo
Lar & Ruth
09-23-2015, 01:35 PM
Concord is east and south of Blue Ridge mountains. About 365 miles west of the outer banks. Suburb of Charlotte.
09-23-2015, 01:45 PM
We'll be between Cherokee and Ashville,,,,,one of God's living rooms. Ya done good on North Caroline, Old Coot!!
09-23-2015, 01:49 PM
We're just MO. transplants from AR & IL.
09-23-2015, 06:07 PM
I have not heard about the Danco silicone paste. I have been using the white thread pipe tape each time about twice a year. Is this similar? Where do you find the Danco paste?
2015 Flagstaff 26VFKS
TV - 2014 F150 Crew Cab 5.0L
WDH - 1,200 Equalizer
09-23-2015, 06:40 PM
Silicone paste
Is silicone paste the new and improved pipe dope I still have a couple cans of the old stuff that I have had at least 25 years
09-23-2015, 06:53 PM
When I remove the anode rod I replace it over winter with a teflon plug
09-23-2015, 07:23 PM
Danco silicone paste is a lubricant only.
09-23-2015, 09:37 PM
RetiredRVer
As is Teflon tape....it is also a lubricant for the threads, not a sealing tape. A RV hot water tank is the same as your home hot water tank, just much smaller. (As far as maintainance goes). Replacing the anode rod is necessary only when it has sacrificed itself. If one is going to leave the rod out all winter, please put a pipe plug in the hole to prevent critters from making a home inside your tank. Draining the tank after each camping trip is un-necessary. But, you can do it if you like!
09-24-2015, 08:27 AM
Teflon Plug,,, very interesting,,, where did you find one of those ???
I would be afraid to leave anode out,,, not knowing what might decide to nest in the WH ???
09-24-2015, 08:40 AM
I'll assume they meant Nylon or PVC not teflon.
