Old 09-10-2010, 08:05 AM   #1
Nights Camped in 2010 - 2
Water in bottom of hwh
Good morning. We are out for another weekend trip and things are going well. Beautiful weather in Gettysburg. I have noticed some water collecting in the bottom of the HWH on the outside. Could be coming out of the relief valve. Have not noticed this before, but wonder if others have experienced this? The HWH is working great. I only use it gas mode. Thanks all.....
George Kelly
2011 Rockwood Ultra Light 2604
Dodge RAM 1500 Larime 4x4, 5.7 HEMI
Nights Camped 2010 = 18
Nights Camped 2011 = 15
sailingsuppo46 is offline   Reply With Quote
Old 09-10-2010, 08:25 AM   #2
Mine does the same thing occassionally. So far I cannot pinpoint what is causing it because it happens very sporadically, and it happens when firing and when idle. It is certainly coming from the relief valve. If it gets worse I may have it looked at, but now it doesn't cause any problems.
grandpaofthree is offline   Reply With Quote
Old 09-10-2010, 08:41 AM   #3
Mr. Black's Avatar
Relief valves are very easy to replace and fairly inexpensive. If you change it and you should be good to go for a long time. Once they start dripping I have never seen one just stop leaking. Some will say it is normal for it to drip a little but I don't like it and would change the valve. I seem to recall the last one I bought was less than 15 bucks. Good lock out there.
Oh and wouldn't it be a CWH or just a WH? lol
Steve
1999 Ford Superduty F250 PSD CC SB 6spd 4x4.
B&W goosneck/companion hitch, Airlift 5000 airbags.
2006 Sierra F28 Rear Kitchen 5th Wheel, 31' = 10k pounds.
Nights camped in 09-14, 2010-23
Mr. Black is offline   Reply With Quote
Old 09-10-2010, 05:17 PM   #4
Thanks. I will monitor it through out the rest of the weekend and see what happens. I haven't seen anymore since cleaning it out this morning. If it continues, I will take it to the dealer since it is still under warranty. Appreciate the help.
George Kelly
Old 09-10-2010, 06:56 PM   #5
Arn
Arn
Any chance your anode rod needs to be tightened? That's where I'd start.
Arn
Arn is offline   Reply With Quote
Old 09-11-2010, 10:19 AM   #6
It's the relief valve. I switched over to AC power and went to check the unit and there it was dripping away. I turned everything off and flushed the relief valve hoping to clear any junk that might be in there. Think I will replace it anyway. Just makes me little ticked off that its a new camper and the relief valve less after three months. So goes being an RV owner... more fun. Later,
George Kelly
rockwood
