Old 07-21-2014, 01:48 PM   #1
Water on floor when showering
Hi all, just came back from our first outing in our Rockwood Minilite 2109s. Everything went well as expected except one problem. When showering, the water would get out and onto the floor. I'd be interested to hear from other 2109s owners how they have cured this problem.
chaslorr is offline   Reply With Quote
Old 07-21-2014, 01:52 PM   #2
Alot of people on the Forum recommended that we add splash guards on both sides
2015 Ram 2500 4x4 6.4l with 2015 Sandpiper 25RLS
Wife, myself and 2 furry kids
Mountndream is offline   Reply With Quote
Old 07-21-2014, 01:54 PM   #3
MMCM/SS
Water on Floor
Somewhere at the base of your shower is a access plate to reach the connection between the shower drain and the holding tank. Find this access and look at the pipe connection with a flashlight with the shower on and water going into the drain.
This is the most likely area for the problem, the plastic pipe connections could have became loose or were never tight. I had this problem on my last camper.
Tooters is offline   Reply With Quote
Old 07-21-2014, 03:53 PM   #4
BruceM's Avatar
On our 2109S the water from the shower head will spray through the fabric shower curtain.
We picked up a plastic liner curtain today.
We may also get one of those plastic over spray blockers that mount on a bathtub wall - available at home improvement stores. We are thinking of mounting one on the shower pan/shower wall junction on the left side.
2015 Rockwood MiniLite 2109S
2018 Ford F150, 3.5L ecoboost
Blue Ox SwayPro hitch
BruceM is offline   Reply With Quote
Old 07-21-2014, 04:43 PM   #5
lswartz's Avatar
I level the TT so that the water runs to driver's side back corner. In fact, I use the shower base to level my TT whenever we will be using the shower camping. We also only spray to that same corner with the shower head & have not had a problem since. It has always been dry since.
I also checked the access panel for the shower base but found no leak there. All the water came over the shower base lip.
2021 Rockwood Mini Lite 2109S
2010 Toyota Tundra 4WD
lswartz is offline   Reply With Quote
Old 07-21-2014, 05:44 PM   #6
Thanks for all the good ideas. Now which one to try first?
show, shower, water
