Old 09-06-2011, 02:48 PM   #1
Water Pump?
I did a wonderfull thing over the weekend. When I put the battery in I decided to reverse the terminal cables. FYI. Not a good idea. It took me a while to figure it out, but I blew both 40 AMP fuses in my Roo 19. But now the water pump doesn't work. Does anyone know A: where the water pump is located in a Roo 19 and if there is an inline fuse or a reset?. I am thinking I may have popped that. I really need to know, because my next camping trip is electric only, so I REALLY need the pump to be working. Thanks.
southpaw821 is offline   Reply With Quote
Old 09-06-2011, 03:03 PM   #2
Triguy's Avatar
Ouch.
I've done that, too...once. But once is enough.
I'm not sure on your model, but you can trace back from the water heater or look under to your fresh water tank and trace up the intake hose.
Either should give you an idea of where your water pump is in your trailer.
Mine is in a cabinet under the front bunk. I've got a 233S.
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
Old 09-06-2011, 03:23 PM   #3
Southpaw, look under the dinette seat closest to the bunk. Thats where it was in my 07. Hope this helps.
Papa Roo is online now   Reply With Quote
Old 09-06-2011, 04:09 PM   #4
bikendan's Avatar
Southpaw, just a suggestion.
there's a Roo section, under "Expandables/Hybrids" forum here.
you posted in the TT/5th Wheel forum's Rockwood section.
since your question is specific to a Roo 19, further questions would get more help in the Roo section.
most of the time, when this happens, there's a tripped inline circuit breaker along the tongue, between the battery and the front of the trailer. it should be able to reset.
