Originally Posted by vrunner
I noticed when I put my finger over the hole of the siphon hose it buids pressure and stops spitting. Is that hose suppose to be clamped/capped?
Sounds like you found the problem.
Cap that line and you're good to go.
If you have a valve that's supposed to shut the line, it might
be turned the wrong way???
Capping the line will make sure.
