Old 06-18-2015, 08:29 AM   #1
Water pump issue
We are headed to Yellowstone and while hooked up to water we have water overflowing our freshwater tank. Any ideas where that check valve is?Click image for larger version
Name:	ImageUploadedByForest River Forums1434634034.880640.jpg
firedaniel is offline   Reply With Quote
Old 06-18-2015, 08:31 AM   #2
In the Pump Head! Youroo!!
youroo is online now   Reply With Quote
Old 06-18-2015, 08:35 AM   #3
It will be on the inlet side of the pump, nice to see that they spray foamed your pump in place .
Ontario
Vibe 6501
1 Prospector Canoe
2 Mtn. Bikes
4 Hiking Boots
Happy Vibe is offline   Reply With Quote
Old 06-18-2015, 08:46 AM   #4
How do I fix that? Pull the pump? Also there is a valve on the inlet would that help? It's the first time we ever used the pump go figure. Lol
Old 06-18-2015, 09:00 AM   #5
First thing is Dis the (City Water Feed) then turn on the Pump,let water run for a MIN. NOW turn off Pump and hook to City Water! If this is not the FIX you need to take pump apart and LOOK for Damage! Youroo!!
Old 06-18-2015, 09:31 AM   #6
Makes since. Gracias!
Old 06-18-2015, 09:42 AM   #7
Does Gracias mean the Pump/Water Overrun is Fixed? Youroo!!
Old 06-18-2015, 08:08 PM   #8
If you've got the winterizing connection that allows you to pump antifreeze with the pump, then there are probably 2 valves on the suction side of the pump, one to the AF connection and one to the FW tank. The one to the FW tank is normally open and the one to the AF connection is normally closed. When you want to add the antifreeze, you swap them. In this case, close the FW tank valve also, and you should be OK, at least until you want to use the FW tank.
(I've also used these to fill my FW tank. Attach your filling hose to the AF connection and open both valves and the water goes from the AF connection into your FW tank. But be careful - do it slow or you can pressurize your FW tank, which is NOT a good thing.)
2011 Traverse LT, 3.6L, FWD
Old 06-19-2015, 01:28 AM   #9
Hooked up tonight and it seems ok. Doesn't appear to be filling the onboard tank. Been watching the level indicator and it's good
pump, water, water pump
