Old 06-24-2016, 12:23 PM   #1
Travelers 500,000+
Water pump not working
Help!
Currently camping. Water pump not working. Rockwood 8319SS.
The first row on panel control nor working. Tank lights, gas water heater light, tank heater, nothing lighting up. Which is where the switch for the water pump is at.
Murmaids is offline   Reply With Quote
Old 06-24-2016, 12:30 PM   #2
NMWildcat's Avatar
First thing is to check all your fuses and breakers
Scott and Liz - Southern NM
Old 06-24-2016, 12:38 PM   #3
Head Rambler
I agree with checking the fuses first. If that doesn't work, it could be a loose connection behind the panel.
Gotta go campin!
Old 06-24-2016, 05:02 PM   #4
Travelers 500,000+
Water pump
We've checked all fuses did that before submitting , including the one by the tongue, looked behind the panel and no fuses there. Thanks for the suggestion.
Old 06-24-2016, 05:12 PM   #5
fonzie's Avatar
check in-line fuse for water pump which is below TV entertainment center, bottom door on the right facing unit.....
Fonzie
Old 06-24-2016, 05:25 PM   #6
Travelers 500,000+
Thanks! I'll give it a try tomorrow night. Heading to a graduation party down state in Michigan! Place we took it to be dewinterized didn't even put the screws back in that door.
Mary B and Ann S
Known as the Mermaids
(Retired )
Michigan Campers/Travelers
Days camped in 2015 145
Old 06-25-2016, 01:07 PM   #7
Chuck.C's Avatar
You said that other panel items weren't working, which sounds like it isn't a problem with the pump or fuse for it. See if you have a second switch, possibly near the water input, that might get you working till you can resolve the panel problem.
2013 Coachmen Mirada 35DL
Chuck, Susan, and dogs- Gracie the Registered SnackHound and Toby the Wonder Boxer
Chuck.C is online now   Reply With Quote
Old 06-30-2016, 11:12 PM   #8
Travelers 500,000+
Water pump
Well, we got a hold of a person who actually works for an RV service center. He came to our campsite. Seems our regular RV service reconnected our LP sensor which we've had problems with since we bought our trailer. They rewired it into our water pump and the guy, disconnected it, reconnected it and we have water. Cost us $20.00. This was great as it seems women get a raw deal at times. Thanks everyone for your input.
pump, water, water pump
