This will be for others in the future who have this issue.
Last week, I was able to get it working via the pump.
I took off the access panel (left side in the cargo hold) and looked at the lines going to the pump to determine that water was just not making it from the tank to the pump.
My solution, I removed the service connection, put it the antifreeze connection, flipped the valve to open, started the pump and the water, once the pump was primed, I closed the antifreeze line and the pump sucked right from the tank.
