Old 03-30-2015, 06:37 AM   #11
bubbles's Avatar
Assuming you are plumbed correctly, yes the antifreeze will be purged when you de-winterize. It is a whole house filter and therefore all pressurized water (pump/shore) passes thru the filter.
Old 03-31-2015, 06:11 AM   #12
Everything I've read about de winterizing says to put water in the holding tank and purge the antifreeze with the water pump. Why not just hook up to city water to purge? Our new 8329SS has an antifreeze inlet port. Do I flush that with city water? Thank you all.
Jim McCormick is offline   Reply With Quote
cat, water
