08-07-2017, 07:53 PM
Water Sitting in Drain of Shower
We noticed today that we can see water in the drain of our 2104S (2018) shower. We emptied the tanks, tried to add more shower water to see if it would overflow, but it just seems to remain at the same level. Is this normal?
08-07-2017, 07:59 PM
Canadian Member
I think what you're seeing is water in the P trap. If it's like ours, there is very little space under the shower pan so the P trap is immediately below the drain. It's perfectly normal.
If you have a removable panel on the front of your shower pan you can remove the panel and see how tight it is under there and why they did it that way.
08-07-2017, 08:12 PM
Thank You
Thank you...that's a relief. We have to store it and we were afraid when we went back to pick it up something horrible might have happened.
08-07-2017, 08:31 PM
Canadian Member
The front panel on ours is held on with 4 or 6 screws. If you can remove yours you'll see what I'm describing and it'll make you more comfortable. It'll also confirm if yours is the same as ours.
08-07-2017, 08:36 PM
When you winterize, make sure you pour anti-freeze in all the drains.
08-08-2017, 09:22 AM
2017 Windjammer 3029w
I noticed the same on my Windjammer 3029w and wondered also when first seeing it. Figured it was the trap after closer look.
08-08-2017, 09:51 AM
The water in the trap is a correct observation.
If you take off that panel to do a look/see, observe how much flex you have in the shower pan around the drain. Mine was significant enough to take the time to correct it. Do a search on flex in shower pans for further info
2016 Flagstaff 27VRL Emerald
14K Equalizer
2020 Silverado 2500HD CC 4X4 6.6L gas 3.73
08-08-2017, 09:52 AM
We live in California so I don't think we need to Winterize....Correct?
08-08-2017, 12:10 PM
Canadian Member
You only need to winterize if it will get below 32°F overnight.
08-08-2017, 12:13 PM
you will see the same thing in every drain in your house except the toilet. There it is built into the Vitreous China casting.
The water is the reason you do not smell the sewer gasses, both at home and in ur camper.
2009 Chevy Silverado 2500HD CCSB LTZ Diesel, Fumoto Oil Drain Valve, Turbo Brake activated, 39 gal Aux Tank W/ Fuel Pump transfer, Air Lift Loadlifter 5000 air bags.
08-08-2017, 12:54 PM
Thank you all for the clarifications. We aren't very handy people and don't know much about these things. This forum is filled with wonderful helpful people. Thanks again!
08-08-2017, 01:06 PM
A picture is worth...well, you tell me.
'04 GMC Sierra 2500HD, CCSB, D/A, MaxBrake, B&W Companion, Retrax Pro, AR Power Steps
2021 Solitude 310GK w/FBP
1969 Camaro RS/SS Convertible
Dad's old 1968 Empi Imp (recently recovered from under 21 years worth of boxes/dust)
08-08-2017, 01:45 PM
YES.... A THOUSAND WORDS!!!! Perfect!
08-08-2017, 03:46 PM
Just remember that if storing it in freezing temps, that standing water will have to be displaced with antifreeze.
08-10-2017, 08:58 AM
While you are at it, add a little black-water tank solution in the shower and sink traps too.
