Old 06-21-2015, 07:04 AM   #31
Wolverine 1945's Avatar
Fabric Softener in your Black Water tank ???
Set the beer down and back away !!!
LMAO !!!
Wolverine 1945 is offline   Reply With Quote
Old 06-21-2015, 07:05 AM   #32
I guess I FAILED? Youroo!!
Old 06-21-2015, 07:20 AM   #33
satdog01's Avatar
Was having issues with the black tank not completely emptying, prior to starting a 120 mile trip last week end, filled the black tank to one third, did the GEO and a cup of Calgon as well. Added more water to the black tank as soon as I got o CG. Watched the dump through my clear elbow, WOW the stuff that came through. Tank sensors seen to be clear all weekend. We carry drinking water, for ice, for coffee from home filter water. Most CG in this area have high linme content which effects the water taste bit. Will start using Calgon in tanks as well. Had to go to second Walmart to find Calgon by the water softners!
Marriot II on Wheels 2017 Flagstaff Classic 832OKBS Diamond Pkg
2013 GMC Denali crew 6.6L 2500 HD DMAX w\Alison Trans
Pepper 🌶 Pomeranian rescue 204 nights as camping buddy
Days camped in FR, 2011 = 20, 2012 = 57, 2013 = 59
....2014 = 39, 15 = 52, 16 = 77, 17 = 81, 2018 = 4
Retired :
satdog01 is offline   Reply With Quote
Old 06-21-2015, 07:20 AM   #34
Only Water Softener I have found in Calgon,,,
Does nobody else make a Water Softener ???
Old 06-21-2015, 07:38 AM   #35
WFD
Originally Posted by Timtation View Post
When you use a softener for the blackwater do you have to regenerate more frequently? Where do you store all that salt not to mention where did you put the softener? Our trailer does not have enough space for a softener for the regular water let alone the black water.
Hold the horses here....nobody is suggesting installing a water softener and using water softener salt. Calgon is simply a jug of liquid water softener people can use in their wash, comes in jugs similar to laundry detergent, which is where you will find it in the dept store. Pour a cup of it into the black tank via the toilet.
2016 Chevy Silverado 2500 Duramax
2016 Rockwood 8289WS, Diamond Pkg.
WFD is offline   Reply With Quote
Old 06-21-2015, 07:51 AM   #36
Only place I found it @ our local Meijer store was in the Pharmacy,,,
In the Bath Isle ??? There was nothing in the laundry Isle ???
Old 06-21-2015, 07:52 AM   #37
Calgon also is sold in (Powder Form)! Youroo!!
Old 06-21-2015, 07:54 AM   #38
The one we found was Bath Crystals !!!
I see Wally World has a 32oz bottle !!!
Old 06-21-2015, 07:56 AM   #39
satdog01's Avatar
As far as liquid water softener, I used Calagon, comes in half gallon jug. Walmart is only box store I found it, Amazon does carry it but at a higher cost The only other softener I know of is the powered form for hot tubs. That would be okay, but I would mix it to get it dissolved prior to adding it to the tank. Might be a good solution for space, pack each shot in a ziplot bag. I bought a 10 pound Box a couple of years ago, still using it. The liquid form is easier to use since I am adding the rest of the liquids in the GEO mix.
Retired :
Old 06-21-2015, 08:02 AM   #40
WFD
Our local stores only carry Calgon in the powder form, but when I get over to the Walmarts in ND, they carry the liquid form...powder will work just an extra step to dissolve it prior to use.
black, black water, tank, water, water tank
