Old 07-19-2014, 09:35 AM   #11
The_Rhino's Avatar
IMO you are taking a big risk towing a (3) slide 5er w/dual A/C with a 1/2 ton Tundra... The good thing is that you now know your actual weights & can make an informed decision as to what to do next.
BTW, we looked at the Rockwood lightweight 5ers but the bunkhouse floor plan was too much for my 2500 (loaded). With our family of 5 & gear it would have pushed us right to the limit & I don't want to tow like that...
2011 RAM 2500 ST Crew Cab 5.7 Hemi ($14K in '13)
2011 Primetime 3150BHD Touring Edition ($20K in '14)
Days camped in 2017-31
2016-36; 2015-37; 2014-31
The_Rhino is offline   Reply With Quote
Old 07-19-2014, 09:52 AM   #12
PhoneDude 8289's Avatar
After reading this I need to get my 8289 to the cat scales. I know I was pushing the GRAW limit, I need to know for sure for my own info. I have around 3k miles of towing the 8289 since January, tows real good but I need to know the actual weight. I too have the 50A, 2nd A/C and a few other extras. I did read on a Tundra website that the axel is made by Hino and that Hino rates the rear axel at 5100#. Don't know why Toyota would rate it lower. "Must be true if it was on the internet"
Joe & Beverly
2014 Ram CTD, CC, SB
2014 8289WS lifted
PhoneDude 8289 is offline   Reply With Quote
Old 07-19-2014, 10:03 AM   #13
dcheatwood's Avatar
I understand that front a/c adds less than 40-50 lbs to pin weight.
2013 Rockwood 8282WS
Reese Revolution Pin, Reese 16K
2008 Tundra Limited Double Cab 5.7L
Air Lift 5000 w/Wireless Air
Old 07-19-2014, 10:53 AM   #14
JoeMazz's Avatar
Originally Posted by The_Rhino View Post
From my understanding, the 1324 pin weight was without the 2nd A/C or any other upgrade features...
When I ordered the unit, the advertised pin weight was 1184lbs; then they changed the 2014 to 1324lbs without any floor plan change, or explanation from FR for that matter.
I called FR after the weight change and they had no answer other than they "might" have moved the axles forward.
How they are unsure of this is concerning to me.
I suspect, and the evidence confirms IMO, there is fudging of the numbers for sure.
2015 Jayco Precept 35UP
JoeMazz is offline   Reply With Quote
Old 07-19-2014, 10:56 AM   #15
JoeMazz's Avatar
I just got back from a 3000k trip, and it pulled awesome. I had to weigh it when the opportunity came because of the bouncing on expansion joints. Some were violent and I had concerns. The weight explains it.
Old 07-19-2014, 11:36 AM   #16
B and B's Avatar
Fully loaded (full water tank) my pin weight on the 8289 is 1750 lbs. Total TT weight 9300 lbs. I have 1900 lbs available according one source changing gears calculates 2200 lbs. I take the lessor of the two as being upper limit.
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
Old 07-19-2014, 12:35 PM   #17
Dave_Monica's Avatar
As you weighed it to calculate actual pin weight, what was the rear axle weight of the truck with the FW hooked up?
Dave
Old 07-19-2014, 02:13 PM   #18
JoeMazz's Avatar
On the 8282ws, the fresh water tank is behind the axle. Filling it, although it would take weight off the pin, it would throw the balance of the trailer way off.
Old 07-19-2014, 02:51 PM   #19
dcheatwood's Avatar
I've traveled with my fresh tank full several times and didn't notice any difference. I believe the driver side is heavier than passenger side too because 2 slides, frig, stove, fireplace, TV, shower, corian counters, microwave, etc is all on driver side. Passenger side only has loveseat slide and pantry. Mine sits 3/4" lower on driver side.
Old 07-19-2014, 04:02 PM   #20
JoeMazz's Avatar
True, and I've done that as well, but I believe that really throws off the "15-18% of the weight should be on the pin" guideline. Another contributor to the bouncing.
1/2 ton, pin weight
