Old 07-20-2014, 05:58 PM   #31
JoeMazz's Avatar
Originally Posted by French View Post
Joe
Do you have light truck tires or P's? I had a nasty bounce coming off bridges etc but much improved with aired right up light truck tires. Trailer tires are at max too and this did improve "bounce" with my rig
E rated filled to 75 psi all around. Airbags at 65lbs.
2015 Jayco Precept 35UP
JoeMazz is offline   Reply With Quote
Old 07-20-2014, 06:31 PM   #32
PhoneDude 8289's Avatar
I run the E tires at 75 and my airbags 35 - 40. I had tried the airbags with as much as 70# in them, anything above 50# felt like the axel was bolted to the frame, no give at all. I generally run the bags at 30# unless on some bad roads.
Joe & Beverly
2014 Ram CTD, CC, SB
2014 8289WS lifted
PhoneDude 8289 is offline   Reply With Quote
Old 07-20-2014, 06:37 PM   #33
JoeMazz's Avatar
Same here. I always ran at 35lbs on the airbags, but with this bad stretch of road I up'd the bags to 65 and it helped, but did not resolve it by any means...
Old 07-20-2014, 07:33 PM   #34
Not much would resolve I-10 in Louisiana except major reconstruction, don't know about SC, had not been through there since late 60's. My next trip that would take me thru LA I think I will try going around that state because of there roads
Joe & Beverly
2014 8289WS lifted
Old 07-21-2014, 10:35 AM   #35
dcheatwood's Avatar
Yep. I have a hard time inviting rvers to LA because of the bad highways. Low bid projects I guess.
2013 Rockwood 8282WS
Reese Revolution Pin, Reese 16K
2008 Tundra Limited Double Cab 5.7L
Air Lift 5000 w/Wireless Air
Old 07-21-2014, 06:52 PM   #36
Joe,
Was out by the cat scales today and got the Tundra weighed. Had a full tank of fuel, DW, our two dogs, tools and most of what we carry in the truck when ready to camp. Also the hitch is in the bed of the truck. Here is my weight ticket. Looks like I'm running a bit heavier than what I seen on your ticket. First chance I get I'll get the RV weighed
Joe & Beverly
2014 8289WS lifted
Old 07-21-2014, 07:26 PM   #37
Herk7769's Avatar
Originally Posted by JoeMazz View Post
Well I finally came across a CAT scale while on vacation and weighed the 8282ws......that explained a lot...and we were almost completely unloaded at the time.
You really can't believe anything the manufacturer says about pin weight...
Attachment 58422
Attachment 58423
AMEN brotha...
HAM CALLSIGN - KC3FFW
1/2 ton, pin weight
