Old 06-07-2016, 09:23 PM   #1
Weight With New rockwood 2906WS
Followed Rons weight guide posted a couple of years ago. Got 3 weights, truck alone, trailer hooked up with w/d bars hooked, trailer hooked up bars off. These are the weights. the trailer weights are 8100#, tongue weight is 1050#, load transferred with w/d bars amounts to 20#. The 1500 Dodge Ram goes down about 1 1/2 inch. I had the Firestone airbags with 10lbs of air.
Jim and Silene
2017 Rockwood 2906WS
2014 Dodge Ram 1500 Hemi 5.7
Firestone Airlift 1000, Equalizer Hitch
Augustpilot is offline   Reply With Quote
Old 06-07-2016, 09:36 PM   #2
Platokidd's Avatar
w/d bars amounts to 20# ? Think your wdh is not doing its job..
Do you have your axle weights for the truck with and w/o bars?
2014 LaCrosse 323RST-TE-C
2009 Chevy 2500HD Z71
nights of camping
2017-67 / 16-92 / 15-73 / 14-60 / 13-33
Seasonal
Old 06-08-2016, 10:30 AM   #3
Why not post your weights so we can see what you are talking about. Maybe you mean the front axle weight was all restored except for 20 lbs?
2010 F250 5.4L 3.73
2011 Flagstaff 831FKBSS
Equal-i-zer 4pt 12K
2010 F250 4X4 5.4L 3.73 LS
EQUALIZER E4 1200/12000
Old 06-09-2016, 06:26 PM   #4
Here are 3 wt tickets
Truck-- steer axle is 3360, drive axle is 2580. Total 5940 plus 2 people 6050 lb
Truck and trailer, st bars connected. Steer axle is 2960, drive axle is 4100, trailer is 7000 Total 14060
Truck and trailer without wt bars connected. Steer axle is 2860. Drive axle is 4260. Trailer axle 6980. TotL is 14100
Talked to equalizer in salt lake about hitch. Said it was not set up right. Should be a lot more than 20 lbs. last place that set up took out Ll but 3 washers, now you can put on equalizer bars very easy. Equalizer says should have at least 5 washers to tilt hitch. Have appointment on the 20th at certified equalizer hitch shop, shall see.
Jim and Silene
Old 06-09-2016, 07:25 PM   #5
You got approx160 lbs off your rear axle, hard to tell exactly with the 20 lb scale tolerances. 5 washers should work a whole lot better.
2010 F250 5.4L 3.73
Equal-i-zer 4pt 12K
Old 06-09-2016, 10:35 PM   #6
Platokidd's Avatar
What concerns me is your 400 lbs. light on the front. Adjustment is needed of the wdh for-sure! When I was towing with my old 1/2 ton I ran 25 psi in the airbags, 10 psi seems low.
Be sure to post back how it goes after adjustment.
nights of camping
Seasonal
rockwood, weight
