Old 01-16-2014, 11:31 AM   #11
TURBS's Avatar
Originally Posted by Dave_Monica View Post
The way that the manufacturer usually calculate the camper's GVWR is the axle rating x2 plus the dry pin weight. Frequently now I see that the manufacturer's spec don't reflect that...I'm thinking that they may be doing more 'cya' and lowering the GVWR's in that the axles aren't the limiter, maybe it's the frame design.
I have no idea what happen with your camper...it would probably work if you had 4000# axles. That could be a course of action...switch to 4000# axles...don't think to would be too expensive. Try to get some pricing from Dexter and Lippert.
Dave
I think you'd be better off buying axles from http://www.dexteraxle.com/
TURBS
golf cart safety instructor
Old 01-16-2014, 12:22 PM   #12
At the moment I am switching to "d" rated tires which will give me over 8000lbs tire capacity. I will load carefully to try and stay under the 7000lb axle rating.
My chance of tire failure is minimized. If there is an axle failure I will be talking to Forest River about their underrated tires and axles. Since I will probably never exceed about 7200lbs on axles I am not to worried about it. I am sure there is a margin of safety built in to the axles.
Fifth wheels are new to me so this is an interesting exercise. All the heavy stuff-water heater, fresh water tank, frig, slide, and most of the storage is near the center of the trailer. There is not much in the upper portion except the bath. So I think it is virtually impossible to load to maximum and have 2350lbs on the tongue.
cadman99 is offline   Reply With Quote
Old 01-18-2014, 09:23 AM   #13
Hoo Dad's Avatar
Originally Posted by cadman99 View Post
I am fairly sure that 225's will interfere with the sturcture.
I don't know if this helps you, but my 8285 tires are 225's from the factory.
2011 Rockwood 8285 WS
2011 GMC 3500 HD 4X4, 6.0, 4.10, SRW
Hoo Dad is offline   Reply With Quote
Old 01-18-2014, 09:26 AM   #14
Well my outside weight and tire sticker says 205/75/15. Plus the existing tire clearance would make 225's iffy.
Old 02-16-2014, 04:44 PM   #15
I have the same trailer made 7/11.Has 4,ooo lb axles with 225 tires. Not sure how you got lower rated stuff
keypunch is offline   Reply With Quote
Old 02-17-2014, 03:15 PM   #16
Mine made in 2008 - Rated load about 9300 - outside sticker says 3500# axles and 205 tires. Have changed to 205 tires "d" rated.
Old 02-18-2014, 10:36 PM   #17
B and B's Avatar
Weighed today - ready for travel -Full propane no water
Truck - 6650 (Dodge Ram 2500 diesel)
Truck and Trailer 15140
Trailer - Unhitched - 8490
Trailer - Hitched - 6700
Pin Weight 1790
Axles rated - 3500
Total Axle Capacity 7000
Tires rated - 1820 each
Total tire capacity - 7280
The total weight is far more than advertised - 7250
Add 40 gallons of water and you are close to the limit.
Cadman,
Your weights look pretty good to me, I am new to 5th Wheel but have been in trailering since the 70's. My trailer is 2013 and has the 4000 lb axels and with 225 tires there is 1 1/2 to 2 inches above the tires. I am thinking of getting smaller D rated tires as well. Need to look at the height of the trailer vs pin on the truck to see if smaller tires can be used.
Brian
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
Old 02-19-2014, 08:42 AM   #18
My real problem is the sticker weights versus reality. Gross weight 9300lbs - axle capacity 7000lbs - pin weight necessary to not overload axles 2300lbs. Don't see anyway you could load to 9300lbs without exceeding axle capacity. I am within about 200lbs of axle capacity and have about 1800lbs of pin weight. So most all of additional weight would have to be pin weight. If I added any water or had a bit in the holding tanks I would exceed axle capacity.
weight
