Old 01-14-2014, 01:57 PM   #1
Weights for 8285WS
Weighed today - ready for travel -Full propane no water
Truck - 6650 (Dodge Ram 2500 diesel)
Truck and Trailer 15140
Trailer - Unhitched - 8490
Trailer - Hitched - 6700
Pin Weight 1790
Axles rated - 3500
Total Axle Capacity 7000
Tires rated - 1820 each
Total tire capacity - 7280
The total weight is far more than advertised - 7250
Add 40 gallons of water and you are close to the limit.
cadman99 is offline   Reply With Quote
Old 01-14-2014, 02:13 PM   #2
Infractee
Did you weigh trailer when empty? What does your yellow cert sticker say the empty weight is? (Not brochure weight)
RhoZeta is offline   Reply With Quote
Old 01-14-2014, 03:14 PM   #3
Fulltime family RVer
That means you've added 1,250 pounds by way of options when the camper was ordered, add-ons by the dealer and things that you added to the camper yourself (propane, pots, pans, food, clothing, linens, etc.).
My guess is that's about average.
It does put you peaking at GVWR of 8,950.
Yep, that 40 pounds will add another 320-ish pounds of weight. Plus 6-10 gallongs for water in the water heater (50-80 pounds). And then a nominal amount in your gray tanks and black tank (say another 10 gallons for 80 pounds).
Out of curiosity- where did you weigh and what was your weighing procedure? (I'm curious because it sounds like you were somewhere that you could unhitch the camper on the scale.)
Old 01-14-2014, 03:29 PM   #4
I wouldn't be comfortable with those weights at all. Especially being so close to the tire rating- typically a weak link. I have 7600 on the trailer axles ready to camp, with 8800lbs. of capacity (2x4400lb), and over 10K of tire capacity.
Old 01-14-2014, 04:59 PM   #5
I didn't buy it new so I don't know what options were added. Brochures either say about 6800 or 7200. The stickers indicate a allowable gross weight of 9300lbs (with propane and water about 1700lbs cargo allowed). If you load to 9300 even with a 2000lbs pin weight you are still over the axle ratings.
I do not have anywhere near 1000lbs (no food, clothing or water) of my stuff it it. No way are you going to load to 9300 allowable and be under the 7000lb axle rating.
When hitched I weighed the front axle of the truck, then the whole truck and then truck and trailer together, then the the rear axle of the truck. I had previously weighed the truck when empty.
Obviously if you know total weight (truck and trailer) and the weight if the trailer hitched and and the empty weight of the truck by axle you can easily calculate pin weight.
So if water is added you are right at the limit of the axles and not far from the tire limit. Tires are what started this - I will look for a 205/75/15 in a D rating (2150). I am fairly sure that 225's will interfere with the sturcture.
My main bitch is placards allowing 9300 gross with 7000lbs of axle. It is impossible.
Old 01-14-2014, 05:23 PM   #6
thetiler's Avatar
I think the Manufactures take the pin weight off the GVW so they can use lighter axles
2013 F350 SB,CC Lariat Ruby Red,3.73Gears,5Star Tuned,,Line-X Bed,Extang Platinum Cover,Airlift LoadLifter 5000 Bags,Airlift Wireless Air controller,Reese Signature Series Fifth Wheel Rail Kit,B&W Fifth Wheel Hitch,2014 Flagstaff 8528BHWS
thetiler is offline   Reply With Quote
Old 01-14-2014, 06:09 PM   #7
Yeah but...... Even if you take the pin weight off the 9300lbs rating you still can't get to 7000lbs.
Old 01-15-2014, 09:36 PM   #8
Infractee
Pin weights are recommended to be 15%~25% of gross, @ 25% pin you would be approx 7000 on axles and 2300 on pin for 9300 ttl.
Just depends on how you load it.
Old 01-16-2014, 08:49 AM   #9
I understand but pin weight percentages are a "fabricated number". Gee if we make pin weights 35% then the trailer will get even lighter. How are you, or the average person, going to load your trailer to get the maximum pin weight? You going down to the scales to load? How am I going to put an additional 500lbs in the bedroom to get to the 25% pin weight? Not going to happen.
They could have spent a few more bucks and used 4000lb axles and d rated tires and been okay. Remember these are frequently sold as half-ton towable. I doubt there are many half-tons that will allow 2300lb pin weights.
There are a bunch of folks who do not read forums like this. They buy a trailer, load it up, based on what the dealer or literature says, and off they go.
Old 01-16-2014, 11:19 AM   #10
Dave_Monica's Avatar
The way that the manufacturer usually calculate the camper's GVWR is the axle rating x2 plus the dry pin weight. Frequently now I see that the manufacturer's spec don't reflect that...I'm thinking that they may be doing more 'cya' and lowering the GVWR's in that the axles aren't the limiter, maybe it's the frame design.
I have no idea what happened with your camper...it would probably work if you had 4000# axles. That could be a course of action...switch to 4000# axles...don't think to would be too expensive. Try to get some pricing from Dexter and Lippert.
Dave
weight
