Old 01-04-2019, 11:07 PM   #1
What are the floors made of and how thick are they?
I bought a 2013 Rockwood Mini Lite 2502S and was wondering what the floor was made of and how thick is it? I want to screw 4 tie down points to secure my generator behind the axle to help with weight distribution. Does the floor have any plywood under the linoleum?
DMS1 is offline   Reply With Quote
Old 01-04-2019, 11:33 PM   #2
cardwellmarty's Avatar
If you have floor furnace vents you can remove them and probably see.
cardwellmarty is offline   Reply With Quote
Old 01-04-2019, 11:55 PM   #3
Floors are a sandwich of styrofoam in between louan on top and louan on the bottom
Malojeer is offline   Reply With Quote
Old 01-05-2019, 12:30 AM   #4
No floor vent. I might just drill a hole in the back of a storage compartment to take a look.
Old 01-05-2019, 12:55 AM   #5
onetonford's Avatar
you can also check where a pipe goes thru floor. I know what mine is but not the rockwood mini lite.
2001 Ford F-350 DRW 7.3
2011 25 RL Wildcat
former fiver 1976 Fourwinds had for 35 years
onetonford is offline   Reply With Quote
Old 01-05-2019, 09:46 AM   #6
Leslie-and-Ann's Avatar
Unless it is a 5er it is a foam sandwich, a 1/8 plywood on both sides foam in the middle. My 5er is 5/8 tongue in groove plywood.
Leslie-and-Ann is offline   Reply With Quote
Old 01-05-2019, 09:53 AM   #7
Some 5ers have the sandwich floor. I think they switched the Rockwoods to plywood in late 2016.
stephndudb is online now   Reply With Quote
Old 01-05-2019, 10:27 AM   #8
Mini Lite floors are luan and foam sandwich until around mid-2017. So I wouldn't be attaching any tie-downs in yours.
2011 Traverse LT, 3.6L, FWD
Old 01-05-2019, 12:41 PM   #9
I agree, l can check mine under the tub access hole. My trailer has sandwich flooring and has a thicker osb on top of the sandwich flooring, it is 5/32. My opinion it is not thick enough to mount to, unless you drilled all the way through the sandwich flooring and used maybe a 1x6 and drilled through it using long bolts and flat washers. The biggest set back is you would have to remove belly covering to see and complete the task.
Old 01-05-2019, 12:52 PM   #10
Correction on floor thickness 5/16, sorry l pulled a floor vent and double checked. My trailer is a 2007 Forest River Flagstaff
floor
