03-17-2016, 12:37 AM
What Generator to run AirCon?
Hi I have a Windjammer 3008w, it come with 13500btu AirCon, does anyone know what generator size I would need to run it?
AirCon is on 240v not 110v.
I also want to use it to charge the batteries when my solar doesnt do the job, my TT has 1200w Solar, 600Ahr of Lithium Batteries and 2500w Inverter/charger.
Would the little EU2000i do the job, I was also thinking of a 3.5kw generator???
03-17-2016, 04:17 AM
One 3500 watt unit, or two 2000 watts paired together. Tons of info on the subject on this forum. Try the search feature.
2015 Micro Lite 25KS
2006 Suburban 2500 8.1 L
03-17-2016, 04:44 AM
240 volt? I would be surprised.
2015 335DS
03-17-2016, 05:05 AM
Yes I did a quick search, couldnt find anything on 240v so thought some smart people here someone will know.
03-17-2016, 05:07 AM
Yes 240v everything in the camper, 2x TVs, Coffee Machine, Washing Machine, Hair Dryer, Microwave, Vaccum Cleaner etc... Im in New Zealand
03-17-2016, 05:20 AM
I bet your "Vacuum Really Sucks"! Is your DC Voltage "24V" also? Youroo!!
03-17-2016, 05:23 AM
2200w Vaccum Cleaner (not built-in)
Running 12v system
All electricity in Australia and New Zealand is 240v
03-17-2016, 05:31 AM
My bad. Of course you are right, there is nothing lower in 240 volt land. Sorry.
2015 335DS
03-17-2016, 05:44 AM
Does anyone know how many watts or amps the standard Rockwood (not sure on the brand) but its a 13500btu Unit, what power draw at 240v? Some smart person will know?
03-17-2016, 06:02 AM
Seems like 5 amps, but here is a datasheet for one unit. http://www.airxcel.com/docs/default-...t.pdf?sfvrsn=6
2015 335DS
03-17-2016, 06:10 AM
Th OP is from New Zeland. 240 V is the norm which I favor. Smaller cables with Higher Voltage carry less Amps. I take 220~240 over 110~120 any time of the day.
2016 Rockwood 2306
2016 Chevy Colorado Z82 / 2009 Pontiac G8 GT
03-17-2016, 07:04 AM
Awesome, thank you. So this is the standard unit Rockwood use? Looks like a 3000w Generator would be enough. I think my inverter is an intelligent one that will add extra power (supplement) from the batteries if I am running other things at the same time.
03-17-2016, 07:09 AM
I don't know exactly which unit you have, but if the BTU is close, the load should be commensurate.
2015 335DS
03-17-2016, 11:25 AM
Also need to check power frequency. May be 50 hz not 60 hz. Need generator that matches.
03-17-2016, 11:33 AM
Left Coast
Military generators...
03-17-2016, 05:02 PM
If unit was shipped for use in the USA, compressor is most likely rated for 197 to 253 volts, 50/60 hz. A 10 amp load at 120 volts = 1200 watts, 5 amp load at 240 volts = 1200 watts. Same running load on generator. Check the full load amps on compressor x voltage to get watts and size generator from there.
Sandy, Lynne & Libby
03-17-2016, 06:21 PM
New Zealand Power is 50 cycle. U.S. Power is 60 cycle. If the generator is from the U.S. It will be 60 cycle. Make sure your appliances especially your air con unit can be used on 60 cycle. There may be potential for damage.
03-18-2016, 08:36 AM
The starting load on motors and compressors is what kills you. I've read that you can run A/C on a 2000 watt Honda if you have an Easy Start that taped irs the load. I haven't tried it yet because of the cost.
https://id144248.webhosting.optonlin...?products_id=4
03-18-2016, 08:56 AM
Originally Posted by mnoland30
A friend just tried his Honda 20i Generator and it ran the AirCon and a TV easily he said. It tripped the circuit when he also put on the microwave.
03-18-2016, 10:04 AM
To sgh77: Did you mean 2000i? Was he running an easy start? What was the elevation. We lose about 10% of performance here at 5000 ft.
