Old 01-10-2011, 12:25 PM   #1
What grease do you use on your bearings?
Hi All.
Been looking into what type og grease I should use on my wheel bearings. The paper on the rig says Lithium complex type and give a few examples.
Mobilgrease HP
Ronex MP
Kendall L-427
Valvoline Val-plex EP grease
Pennzoil Premium Wheel Bearing Grease 707L
I'm wondering if a basic Lithium grease with moly is still good?
The specs are almost the same but you definitely want a Dropping point temp at least 500 degrees F. Also with a viscosity of a minium of 80. and higher is better.
Your thoughts?
Old 01-10-2011, 01:59 PM   #2
Wanna Be Camper
SaskCampers's Avatar
Lucas Oil | Hi-Performance Lucas Oil Products Inc.
This is what I use in all my wheel bearings.
John & Deb
2011 Flagstaff V-Lite 30WRLS
Old 01-10-2011, 02:01 PM   #3
Sgt. Schultz's Avatar
I am partial to Lucas Oil products and have the following to do my bearings (soon as time permits ) http://www.lucasoil.ca/data/tech_XtraHDGrease_eng.pdf
PT Avenger 33BHS-TE
2020 f-250
Sgt. Schultz is offline   Reply With Quote
bearings
