Old 04-23-2014, 08:42 AM   #1
f150k's Avatar
wheel nut torque specs
I have 2013 Rockwood 8282WS 5th wheel what should the rims be torque too?
I was told 95 to 100 ft lbs and also 115 ft lbs
f150k is offline   Reply With Quote
Old 04-23-2014, 08:52 AM   #2
Brother Les's Avatar
110 is around the right setting I go by. Don't just torque and never check them again.
Check your wheels before, and during every trip as you check your air pressure.
Don't over torque because every tire you put on, down the road you will need to take it off....
Brother Les
Old 04-23-2014, 08:53 AM   #3
Depends on stud size and whether steel or alum wheels.
Attached chart is for alum wheels.
File Type: pdf Flagstaff TT Alum Wheel torque specs.pdf (311.4 KB, 188 views)
Old 04-23-2014, 09:17 AM   #4
100 does it for me. It took a couple thousand miles before they completely locked in place.
2011 Flagstaff 831FKBSS
2010 F250 4X4 5.4L 3.73 LS
EQUALIZER E4 1200/12000
Old 04-23-2014, 09:23 AM   #5
BamaBob's Avatar
and....
If you happen to have a Harbor Freight nearby, they sell Torque Wrenches at a VERY reasonable price (Like under $20 reasonable price!)
Nights Camped: 2013 - 242014 - 422015 - 56Jul 2016 - Fulltime
BamaBob is offline   Reply With Quote
Old 04-23-2014, 09:25 AM   #6
Todouble's Avatar
I've got 16" wheels and mine are 100 ft/lbs.
Todouble is offline   Reply With Quote
Old 04-23-2014, 12:02 PM   #7
f150k's Avatar
I have 15" alum rims, does that help?
Old 04-23-2014, 12:15 PM   #8
Rim size makes no difference, it is the stud size that determines the torque. Better to go half way between min and max. If I were using the cheap torque wrenches from HF or NT, I would go to the max listed. I have a calibrated Williams, so I go to the center, which is 110lb/ft for 1/2" studs.
Old 04-23-2014, 01:07 PM   #9
f150k's Avatar
It looks to be 1/2, I used a 3/4 deep socket on the lug nuts, does that help?
Old 04-23-2014, 01:40 PM   #10
Not really, take a 7/16" socket and see if it will fit over the stud, if not, try a 1/2" socket. If the 1/2" fits over the stud, then you have 1/2" studs and torque them to 110 lb/ft.
wheel
