Old 07-11-2015, 07:10 AM   #1
Wheel width on 2504s
The wheel spacing on my recently purchased 2504s has got me baffled. I can no longer use my x chock as it is too wide to insert between tires. I found another x type chock from winfield which I believe will work. My issue now is with what material/product to use to level side to side. If I use lynx leveler blocks I can only go 2 blocks high because of the limited spacing between tires. Of course I could set the blocks behind both tires and drive backwards until the tires are resting on their appropriate blocks. That seems like a pain as I would have to make sure my measurement between the blocks I setup are exactly lined up with bottom of each tire. I do not want to carry a bunch of wood with me and do not want to get concrete pad sites everytime I go camping to be perfectly level when I pull in. Anyone have this problem? Any suggestions? My tires are literally like 3 inches apart at their closest point. I will respond to any comments if more info is needed. I would appreciate some input. Thanks.
vanreever is offline   Reply With Quote
Old 07-11-2015, 07:23 AM   #2
Ford Idaho's Avatar
If I may suggest.
https://www.google.com/#q=anderson+levelers
Old 07-11-2015, 07:27 AM   #3
I looked at the anderson levelers. They are definitely on my short list. I have to look at the specs. I bet I would have to saw one down a bit to fit between the tires. Thanks for the quick response.
Old 07-11-2015, 07:31 AM   #4
Ford Idaho's Avatar
If you do all you need to do is cut off the lower (thick end) corner.
Like so.
Old 07-11-2015, 07:40 AM   #5
Thanks. This is what I am working with.
Old 07-11-2015, 07:41 AM   #6
Or this? Youroo!!
Old 07-11-2015, 07:53 AM   #7
greti's Avatar
We've just used the yellow leveling blocks. Stacked them up to needed height and long enough for both tires to fit on them. I purchased the Anderson levelers and had to cut them back to fit. However I've not had a lot of luck as they seem to slide on gravel?? So they sit in storage and haven't been used again. It's likely operating error����
Tennessee
2014 Rockwood Mini Lite 2504s
2006 Ford Expedition
greti is offline   Reply With Quote
Old 07-11-2015, 08:18 AM   #8
May have to trim the Anderson's a little more. Some have cut the leading edge off about 1"-2". The 2nd picture shows even more trimmed from the back corner. Trim both of them so you don't have to sort them. I also ran a rope thru the small hole and tied the wedge to the ramp so they don't get separated.
Name:	Anderson Leveler corner.jpg
ID:	82579   Click image for larger version
ID:	82580   Click image for larger version
Old 07-11-2015, 08:21 AM   #9
Ok thanks everyone. I really appreciate the responses. I have two weeks until her maiden voyage so I will try to work it out.
Old 07-11-2015, 02:51 PM   #10
I'm not sure what your issue is with this. It's what I've been doing with my Camco blocks. You put 4 on the bottom in front of the front tire, then build them up. You might need to purchase another set of blocks if you need to go up higher than a couple rows. I have two sets, and I cut one block in half. That's lets me "end" a row twice with a half block, instead of having to use 2 full blocks. My BAL X-chocks also fit. (I think my tires are 2 3/4" apart. Same on both my Roo and my Mini Lite)
2011 Traverse LT, 3.6L, FWD
wheel
